The Best Transmission Fluid Recommended
Old 01-28-2010, 11:51 AM
motorhead426's Avatar
motorhead426
motorhead426 is offline
I've always used Mopar ATF +4. Just take your own container and buy it from the dealers bulk container. It way cheaper that way. Besides, its ATF. Unless you have a diesel with monster power, does anyone really need aftermarket ATF? It's not like you'll get better MPG's, and power. I run RP in my axles, and Mobil 1 in the engine, so I'm not against aftermarket brands.
On another note, with chrysler transmission history, so you want to chance anything in there but the Mopar stuff? I change mine every 15k and the filter every 30k. my trans temp never gets above 150deg in the summer here in Michigan. Just my $.02
  #22
Old 01-28-2010, 01:48 PM
abarmby's Avatar
abarmby
abarmby is offline
Cheers for the advice weedahoe and RubberFrog. I guesss it's just the dealers trying to stiff me again, as RP is SOOO much more expensive than the Mopar atf+4 over here.
Al
  #23
Old 01-28-2010, 02:22 PM
truckin151's Avatar
truckin151
truckin151 is offline
I use valvoline, same stuff as the mopar atf but cheaper.
  #24
Old 01-28-2010, 03:16 PM
OlDirtyJohn's Avatar
OlDirtyJohn
OlDirtyJohn is offline
precisely why i got that this time around instead of RP.
  #25
Old 01-28-2010, 07:04 PM
lxman1's Avatar
lxman1
lxman1 is offline
Site Moderator
Dodge Forum Moderator
My local WalMart sells Mopar brand ATF+4, I think. I'll have to check the price on it next time I'm there.
  #26
Old 01-28-2010, 09:52 PM
Ron69697's Avatar
Ron69697
Ron69697 is offline
Could i use Royal purple for my 4.7L? because i would love to hop on that train. Would i notice any changes from the regular oil i use now(which is really cheap oil) if i switch to royal purple?
  #27
Old 01-28-2010, 10:09 PM
bolang's Avatar
bolang
bolang is offline
I use Royal Purple in my 07 4.7 every oil change.
  #28
Old 01-28-2010, 10:25 PM
butch1581's Avatar
butch1581
butch1581 is offline
Our Trannys will suck no matter what fluid you put in them!
I used Quaker State ATF+4
no probs
  #29
Old 01-28-2010, 10:36 PM
Ron69697's Avatar
Ron69697
Ron69697 is offline
no probs
is my tranny goin to screw me over later? i thought that was with the 1999and lower model rams!
  #30
Old 06-08-2013, 07:25 PM
StephenSlampa's Avatar
StephenSlampa
StephenSlampa is offline
Cool Anyone tried Amsoil transmission fluid?
I have a 2006 Mega cab 2WD Hemi (545RFE) with 60k miles. I have a friend that likes Amsoil oil & transmission fluid. The wear tests appear to support his opinion. Any other opinions out there?
Quick Reply: The Best Transmission Fluid Recommended
