Question?
Old Jan 24, 2010 | 10:25 PM
hoss67's Avatar
hoss67
Default Question?
Could someone explain the backside setting on rims for me, I really dont under stand. Thanks Dudes
Old Jan 24, 2010 | 11:02 PM
kllrbee's Avatar
kllrbee
Do u mean backspacing?
Old Jan 25, 2010 | 12:40 AM
4.7Ram5.7Rango's Avatar
4.7Ram5.7Rango
Probably does mean backspacing. Bump for some info, im in the dark a little too, but been ashamed to admit it, lol. I just nod my head and say ok
Old Jan 25, 2010 | 12:53 AM
mmstar23's Avatar
mmstar23
alrighty.....basically backspacing is the amount of space there is between the back of the wheel...think of a deep dish wheel and where the spoke are placed...where the section of the wheel that bolts up to your hub, the more back space you have, the more tucked in your tire will be under the fender, because there is more wheel behind the mounting point. the less backspace you have the more wheel is out side, thus pushing your wheel/tire setup out more, making it look like a roller skate. hope this makes sense.
Old Jan 25, 2010 | 01:17 AM
4.7Ram5.7Rango
Yessir, I believe I see the light! Now I can use my newly "found" knowledge for when I buy my rims....................in the next 5 years hahaha
Old Jan 25, 2010 | 01:38 AM
Desert_Ram's Avatar
Desert_Ram
does anyone know the backspacing on a stock dodge 20" the pedal style?
Old Jan 25, 2010 | 02:02 AM
cheapbeater's Avatar
cheapbeater
yup, like mmstar said... backspacing is the distance from the "pad" of the wheel (the part that touches the hub) to the inside edge of the rim.
i think the factory backspacing was about 4.5?
Old Jan 25, 2010 | 07:48 AM
cwboyjohnny24's Avatar
cwboyjohnny24
I think the backspacing on the factory 20" rim was a little less than 4.5. That's the reason a lot of suspension kits tell you you need new aftermarket rims with atleast 4.5" of backspacing. When I first got on the site Hammer let me know that none of dodge's factory rims had that kind of backspacing when I was looking into a lift.
Old Jan 25, 2010 | 03:58 PM
hoss67's Avatar
hoss67
so for a 2 inch leveling kit i need a 4.5 backspacing tires which is what a dude told me, so to make sure i understand the high the number the more the tire is tucked un the fender, so a 0 backspacing would be better for a larger wider tire?
