Just ordered myself my first cb.
Old Jan 29, 2010 | 03:02 AM
Senomar_DTK's Avatar
Senomar_DTK
Default Just ordered myself my first cb.
I had some extra cash so I bought myself that cobra dx iv since I wanna start out with something less expensive and simple. Also got a k-30 magnetic antenna for it since I don't want a huge antenna sitting on my truck and the k-30 seemed ok size.
Still gotta figure out where I will want to mount it and hopefully it will be easy to hook up.
If you got any suggestions or whatever just comment.
Old Jan 29, 2010 | 03:26 AM
southernbnb's Avatar
southernbnb
ur very next step should be to go to radio shack and get a PA horn and mount that bad boy behind your front bumper. your cobra has a PA function. when you arent using it as a cb you can make yourself cry from laughing so much by messing with people over the PA!!! its freakin awesome!! lmao
http://www.radioshack.com/product/in...ductId=2104031
Old Jan 29, 2010 | 07:16 AM
lxman1's Avatar
lxman1
Site Moderator
WOW, they still make CB,s?
Old Jan 29, 2010 | 08:33 AM
ramhunter9's Avatar
ramhunter9
IMO the K line is ok but the real talker is the willson . i have the willson 5000 on my suped up cobra. with all my CB mods and the linnier im doing about 800 watts. as far as mounting hear is mine ...
Old Jan 29, 2010 | 07:52 PM
NJFF5860's Avatar
NJFF5860
Be sure to calibrate the SWR! K line almost always has to be adjusted (Raised or lowered) Run a K30 myself on roof! http://www.roadtripamerica.com/Equip...io-Antenna.htm
Old Jan 29, 2010 | 07:53 PM
NJFF5860's Avatar
NJFF5860
Running the same unit RAMHUNT!
Old Jan 30, 2010 | 02:34 AM
Senomar_DTK
Ok so I cancled the order on the cheaper cobra 19 and instead i ordered the cobra 29 ltd with Bluetooth since I did some better researchin.
But now with this hooked up will it put any strain on my battery? I don't know much about that and just wanna be safe and make sure I can run this along with all the other things.
Any help would be appreciated
Thanks again
Old Jan 30, 2010 | 03:03 AM
NJFF5860's Avatar
NJFF5860
Have left mine on with the truck off for an hour and no problem. While running no issues either. Good choice on the radio pic. If possible get it peaked from the company your buying it from if they offer that service! Gives you a bit more wattage power for transmitting and recieving.
Old Jan 30, 2010 | 03:24 AM
Palm's Avatar
Palm
800 watts? Wow, I've never ran that kind of power on my ham rig in my vehicle. That's incredible power for what you are doing and I sure hope the FCC doesn't read this forum. Other than DX, there are going to be a lot of people that can hear you that you will never hear. Good luck!
Old Jan 30, 2010 | 03:49 AM
Marx's Avatar
Marx
could put it on a relay to the cig lighter so it will be on only if the key is at acc or on position
