abs, esp/bas/traction control light on
Old Feb 4, 2010 | 06:18 PM
ohiogary's Avatar
ohiogary
Default abs, esp/bas/traction control light on
I am hoping someone can give me guidance on this issue, Yesterday while I was driving all three lights came on and stayed on for 10 miles or so then went off, done the same thing later on. Then today when I started the truck they were on, stayed on for about the same amount of time, came back on again. I was going to autozone today and see if they could run the codes but the lights were off. Any idea where to start to narrow this problem.
Thanks
Old Feb 4, 2010 | 06:54 PM
cwboyjohnny24's Avatar
cwboyjohnny24
What year is your truck??? Have you tried the key trick to pull the codes on the motor? You may also want to look at your wires on the battery and make sure everything's secure. The ground, both ends and the positive the same way.
Old Feb 4, 2010 | 07:08 PM
ohiogary's Avatar
ohiogary
Default infor
Its a 2007 Ram 5.7, no I havent tried that yet, but will do so right now, Im not sure about the key thing,
Old Feb 4, 2010 | 07:17 PM
cwboyjohnny24
https://dodgeforum.com/forum/3rd-gen...ine-codes.html
That's the key trick to pull motor codes. The only reason I asked that is when your truck starts shooting out lights at random times it is sometimes the electrical system messing you up. Such as your battery going bad or even your alternator.
Old Feb 4, 2010 | 08:08 PM
ohiogary's Avatar
ohiogary
I tried the key trick and if didnt show any codes, just read the mileage. The truck is a laramie edition, so it has quite a bit of electrical, I havent noticed any change whether I am driving at night with the lights on or during the day. I really appreciate the advice.
Thanks
Old Feb 4, 2010 | 08:15 PM
cwboyjohnny24
The key trick may not work on your newer truck. I did mine and when I pulled it with no codes where the odometer is it says done if there's no codes. Do you have no warranty on your truck?
Old Feb 4, 2010 | 09:43 PM
ohiogary's Avatar
ohiogary
Default warranty
Yes I did purchase a warranty with the truck, covers most sensors, 100.00 deductable, I was hoping it would have been like a wheel sensor abs sensor that I could purchase and take care of problem. I have made arrangements to take it to the shop next wednesday and I will probally do so if I can not figure out whats going on with it. Surprises me with 3 warning lights on at the same time
Old Feb 5, 2010 | 06:20 PM
ohiogary's Avatar
ohiogary
Default ideas
Anyone else have any suggestions or have similar issue with a ram
Old Jan 4, 2014 | 06:19 PM
DLangford115's Avatar
DLangford115
I have a 2010 ram 1500 with the same issue. I took mine to my local dealer and they told me that the clock spring (steering angle sensor) was bad. They also said that it wasn't covered in my power train warranty. They said they could fix it for around $350. So, I am also wanting to know from anyone who reads this, does this sound right?
