2006 Ram quits running after fill up.
Old Feb 7, 2010 | 10:08 PM
1bata's Avatar
1bata
Default 2006 Ram quits running after fill up.
Has anyone else had this problem? The last 2 times I have filled my truck up, it has quit running. I pull away from the station, and it immediately dies. No check engine light or anything. I let it set for about 30 seconds, and it starts back up. Once I come to a stop, it dies again. Wait about 30 seconds, and it starts back up.
Old Feb 7, 2010 | 10:10 PM
rcman0056's Avatar
rcman0056
probably the fuel pump
Old Feb 7, 2010 | 10:14 PM
SMKNRAM's Avatar
SMKNRAM
In my experience a fuel pump will work or it wont! typically it wont be an on and off problem.
Old Feb 7, 2010 | 10:35 PM
ahook168's Avatar
ahook168
Trash or water in the tank. When you fill it, the stuff gets sturred up. then settles out of the way. Just an idea. Try a bottle of heat first then see what happens
Old Feb 7, 2010 | 11:05 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
didnt someone else just have this SAME issue and he said he dumped the fuel tank and filled it back up with different gas and it worked
Old Feb 8, 2010 | 07:29 AM
1bata's Avatar
1bata
Next time I need to fill up, I'm only going to put about 3/4 of the tank full. See if it does it that way. I'm just wondering if there is a ventilation problem?
Old Feb 8, 2010 | 08:48 AM
4.7Ram5.7Rango's Avatar
4.7Ram5.7Rango
If anything, don't let it get below 1/2, then fill'er up that way. And yes Weed, I, for the life of me, can't think of his name (Drake**** or something to that effect) had this same problem in his 3/4ton, and went through the process of dropping the tank.
Old Feb 8, 2010 | 08:59 AM
cwboyjohnny24's Avatar
cwboyjohnny24
Sounds to me like a ventilation problem as well. Sounds like the pump is working there's just some sort of air lock going on. Does it continue to do this after you've used some of the fuel or does it stop say just below full?
Yes, it could also be sediment in the tank.
Old Feb 8, 2010 | 09:35 AM
chevyguy1973's Avatar
chevyguy1973
Had a similar problem some years back with another truck. Turned out to be the rail mounted fuel filter was clogged up. I'd have to agree it's probably not the pump, but maybe a partly blocked/clogged screen in the tank?
Old Feb 8, 2010 | 10:37 AM
SMKNRAM's Avatar
SMKNRAM
All my fuel pumps have always worked right up til they quit, then never worked again!!
