torque control mod for early 3rd gen's
Old 02-09-2010, 08:57 PM
meen green machine's Avatar
meen green machine
meen green machine is offline
Default torque control mod for early 3rd gen's
so i did the torque control mod on my 2002 4.7. it didnt seem like much of a difference. im wondering if i needed to wait a while before hooking the battery back up after hooking everything else up so the PCM would reset
Old 02-09-2010, 09:19 PM
John  M's Avatar
John M
John  M is offline
Did you have a programmer already? They do 90% of what removing the wire does. If you were totally stock and pulled the wire it should be a night and day difference in how it shifts at full throttle.
Old 02-09-2010, 09:23 PM
meen green machine
no dont have a programmer. and i ran ran it to about 5600 rpm's and it seemed that it had a little more pull its just my truck has 150,000 miles on it so im really not the biggest fan of WOT. and when i did take it to full throttle when it shifted my transmission squeeked which it has done before at WOT conditions. will i be able to telll and difference at lighter throttle conditions maybe at like 4k rpm's
Old 02-10-2010, 12:07 PM
John  M's Avatar
John M
John  M is offline
Torque isn't limited at part throttle so it changes nothing except full throttle operation.
I don't know how it works on 02's and/or 4.7s but it's a huge difference on 03's. It really slams the gearshift instead of easing from 1st to 2nd.
Old 02-10-2010, 12:10 PM
Shiloh 24's Avatar
Shiloh 24
Shiloh 24 is offline
Never heard of this mod, is it do-able with my 5.9?
Old 02-10-2010, 04:26 PM
meen green machine
Shiloh 24Never heard of this mod, is it do-able with my 5.9?
As far as i know i dont think its able for the 5.9's because they have different transmissions. thats what ive red on other post
Old 02-10-2010, 04:49 PM
new2this's Avatar
new2this
new2this is offline
i have asked this question many times and my search wont turn up any results. how do i do this to my 02 4.7? i really want to do something cheap and easy.
Old 02-10-2010, 04:53 PM
meen green machine
on your passenger side fender well theres a harness close to the firewall. unbolt that and there will be a yellow wire with green stripe on it. pull the red piece of plastic out from the inside of harness and pull the wire or use a jewleres screwdriver to push it out. tape off the end of the wire and leave it out then reinstall harness. there should be a 10 next to the wire on the backside of the harness
Old 02-10-2010, 05:44 PM
AF_HEMI's Avatar
AF_HEMI
AF_HEMI is offline
holy crap people. SEARCH BUTTON. this is another issue that gets hashed to death. Shiloh-- no its not available to the 5.9 because you have a different tranny.
but seriously "TMR delete". search it
Old 02-10-2010, 05:47 PM
Shiloh 24's Avatar
Shiloh 24
Now I had heard of TMR but never torque control mod. Sorry AF but I didn't know what he was even talking about until it was explained.
Quick Reply: torque control mod for early 3rd gen's
