Will a 2007 1500 rear axle fit an 03?
Old Feb 12, 2010 | 06:32 PM
freestyledude's Avatar
freestyledude
Default Will a 2007 1500 rear axle fit an 03?
Need to replace my rear diff and was wondering if they'd be the same design? Would this be a bolt on or way more trouble than it's worth?
Old Feb 12, 2010 | 10:13 PM
HemiLonestar's Avatar
HemiLonestar
02-08 1500 rear axles should be all the same.
Old Feb 12, 2010 | 10:44 PM
freestyledude
That's what I thought, I haven't found anything that has said that they have changed
Old Feb 13, 2010 | 01:51 AM
HemiLonestar
I will say they are different part numbers, at least between 03 and 08, but from what I can tell visually there's no difference.
Old Feb 13, 2010 | 02:43 AM
abarmby's Avatar
abarmby
Sounds like someone unfortunately, has the retaining clip issue here?
Al.
Old Feb 13, 2010 | 03:31 AM
05RamMan's Avatar
05RamMan
Why would you replace the whole axle for the retaining clip issue?
Old Feb 13, 2010 | 03:38 AM
abarmby's Avatar
abarmby
As the clips work there way out of the LSD pockets, as the axel turns, the sharp ends of the clips cut deep into the carrier and the bearings.
This renders the whole axel useless as the bearings actually sit in the axel.
The scoring can be so great, that the entire axel assy has to be replaced.
Al.
Old Feb 14, 2010 | 05:22 AM
05RamMan's Avatar
05RamMan
Didnt realize it got that bad.
Old Feb 14, 2010 | 08:24 PM
me0418840987's Avatar
me0418840987
Just installed an axle out of a 2500 van in my 05 1500. Took a week, new tires shortened driveshaft etc, but was worth it. I replaced pinion bearings and clips 4 times before, and finally got sick of it. Once I shortened the shaft, there was no turning back, and it all worked out. new parking brake cables and 8 bolt on rear/5 on front, but I now have 4.10 and a heavier duty posi. takes some mechanical knowledge, but no special tools, if you take your time. To the dealer on wed to have the speedo calibrated, 7mph fast right now.
Old Feb 14, 2010 | 09:58 PM
RedTruck-VA's Avatar
RedTruck-VA
Does the 2500 rear end housing have the speed sensor pickup as the 1500?
