BFG Mud Terrains
had the AT KOs and I couldnt wait till the tread burned up. Always loosin grip on the pavement and horrible in the rain. Only plus side to them is they took quite a few screws and nails and never had a blow out. Performance wise on and off the road, was not impressed at all. Now my new ones on the other hand, probably will never buy a different type of tire again
The Toyo's are better for on road driving. Not as loud either. But in the mud, NO. I would prbly get the Toyos if i got a pair of MTs though.
With my 2wd I want the best traction possible, if I'd had the money I'd be sittin on Mud Graps right now but I had to settle for these Coopers. Hopefully within the next few years when I need new tires I'll have enough saved, I want to do a 3" body lift with maybe 35" Mud Graps if I can fit em under there.
Everybody is always talkin bad about BFGs. Honestly 285s and 33" BFG ATs are the only tires I have bought in the past ten years. They have ALWAYS gotten me where I have needed to go and most of the time in 2wd. Sand, rocks, mud, cross country, and the only time I've had to use my spare is in Nov when I bent the **** out of a steel rim and just had the tire switched over to my spare rim. I'm not saying there the best tire there is but I've not had any complaints. If I was going to buy a new set of tires for my Ram I think I would get the new KM2s.
the graps just look so much MEANER!!!! And look so much bigger!
I've had both BFG Mud Terrians and All Terrians. The Muds wear fast on road. But I had always had god luck with them off road. But being that I live in the desert I haven't had them in mud to much. What I liked about them was the thick side walls. They hold up when rubbed up against rocks. I also had BFG A/Ts and had good luck with them also. they did very well in snow and lasted pretty well on road compared to the mud terrains. I have now gone to Bridgestone Revo A/ts ,because I drive on road now more than off road.
