slows down going up hill
Old Feb 13, 2010 | 06:01 PM
maxxguy1's Avatar
maxxguy1
Default slows down going up hill
I have a 2004 ram 1500 hemi it slows down going up hills I can be going 75 and it drops to 65 or so towing is even worse I have a 04 f-150 that dose not do this. I would like to know what I can do to Improve this with out changing out the gears and with out spending to much money.
Old Feb 13, 2010 | 06:05 PM
JoeHemi's Avatar
JoeHemi
Not sure, I never had that problem. Have you done a compression test on the engine? If it's slowing that bad, seems like you are have some pretty big problems.
Old Feb 13, 2010 | 06:10 PM
MOPAR78's Avatar
MOPAR78
Wow!! A Hemi slowing down!?! I'm clueless!! It's got to be something... Maybe a code will show up soon...
Old Feb 13, 2010 | 06:47 PM
BEAR's Avatar
BEAR
Thats just plain lack of power. How many miles are on the truck? have the plugs been changed lately? Air filter? TB cleaned?
Old Feb 13, 2010 | 07:30 PM
HammerZ71's Avatar
HammerZ71
yeah, that's not typical at all, I have had a Furd F150 with the 5.4 in it and I have my Hemi weighing in at a minumum 1000 lbs more than the Furd did and it would still eat the Furd for breakfast uphill, downhill, flat land, wherever...
Old Feb 13, 2010 | 10:37 PM
oefootball_70's Avatar
oefootball_70
gravity
Old Feb 13, 2010 | 11:12 PM
lxman1's Avatar
lxman1
Site Moderator
If over 30K miles on the spark plugs, they need to be changed for sure.
Old Feb 13, 2010 | 11:21 PM
RedTruck-VA's Avatar
RedTruck-VA
Too many varibles to acurately diagnose. Tune-up, dirty air filter, damaged exhaust, emergency brake drag, low tire pressure, big tires.
Old Feb 14, 2010 | 03:46 AM
maxxguy1's Avatar
maxxguy1
thanks guys just bought the truck 2 weeks ago so not sure when the plugs where changed everything else seems fine i need to get under the truck and listen for exhaust leek, the engine has 147000 on it how much would plugs run I know there is 16 of them. oh the tires are brand new bfgoodrich 275/60r-20 and i just cleaned the k&n filter
Old Feb 14, 2010 | 04:03 AM
JoeHemi's Avatar
JoeHemi
around $2 a plug if you stick with the Champions that you can get anywhere. They're good plugs for the hemi. Get the champion stock number 570. The plug number is RE14MCC4, and the gap is .045. Could also look at the plug wires and make sure they arent cracked. I'd recommend replacing those too with that kind of miles.
If I were you, I'd also clean the throttle body too. Gear oil, transfer case, trans oil, motor oil, and brake fluid should get replaced. With those miles, I'd also suggest coolant and power steering fluid change as well.
What gears do you have? The 3.92s are fine but if you have the 3.55s, they'll be rough towing with.
