Nerf bars with body lift?
Old Feb 15, 2010 | 04:12 PM
rydesolow's Avatar
rydesolow
Default Nerf bars with body lift?
OK, so I need some opinions. I have a ram with 6" suspension and 3" body. I want to get some black nerf bars so my GF stops complaining about getting in the truck, do any of you have nerfs with a body lift? I dont want the damn things to hang down really low and look like garbage, is there anyway I can tuck them so they are only a few inches lower than the body of the truck? If I remember right, most nerf's just mount into the body mount locations, using longer bolts. Will I need super extra long bolts then too b/c of the spacers from the PA body lift? Too much junk just for nerf bars I think. Anyone running them with a pic?
Old Feb 15, 2010 | 04:23 PM
oefootball_70's Avatar
oefootball_70
Run the electronic ones that flip down, MM has a set. They are sick.
Old Feb 15, 2010 | 04:29 PM
senselesscreationz's Avatar
senselesscreationz
heres mine i have a body lift, took the westin nerfs that where on the truck and cut the bracket back to lift the bars up to the truck so there is no gap
Old Feb 15, 2010 | 06:19 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I can show you some pics of mine with them set as they originally were before the BL. As you can see they, can be left alone or new holes drilled in the brackets and raised. It just depends on what you like. And the bolts that come with the PA BL are fine. You wont need longer.
Old Feb 15, 2010 | 06:21 PM
jk360's Avatar
jk360
i just cut 3" off the brackets and drilled new holes so they sit at the same height before the lift.
Old Feb 15, 2010 | 06:29 PM
senselesscreationz
yea what he said thats all i did just modify the brackets for the 3" body lift
Old Feb 15, 2010 | 09:17 PM
rydesolow's Avatar
rydesolow
awesome, just the perfect info I was looking for. going to grab the black ones. any brand you guys suggest? and same as a bullbar, getting a black one, did you also mod those brackets?
Old Feb 15, 2010 | 10:07 PM
senselesscreationz
i have westin and brackets i just cut 3" off
Old Feb 15, 2010 | 10:56 PM
Curiusgeorge's Avatar
Curiusgeorge
For a little more coinage, you could do the Nfab Dominator bars, they look sick on a lifted truck. I've got black Westin bars and will eventually switch to the Nfab's once I get a lift on.
