noisey door panel...
Old Feb 15, 2010 | 05:50 PM
BadHab1t's Avatar
BadHab1t
Default noisey door panel...
i have a noisy drivers side door panel it creeks and squeeks....its not loose but that damned door lock makes noise and i hate it...the actual panel itself creeks and makes noise....annoying as hell...what have yall done to stop this ? i was wondering if i used like foam weather stripping and stuck it on there and then reattached my d.p if that should work....i know others have had this issue but cant seem to locate what they did to resolve it....any ideas guys.....
Old Feb 15, 2010 | 07:19 PM
LinerJoe's Avatar
LinerJoe
I have the exact same issue with my passenger door. It doesn't make any noise unless someone is sitting there and touching it. As long as I'm the only passenger in the truck, it doesn't make any noise.
I did remove that door panel once, so I'm assuming I must not have put it back together 100% correctly.
I just haven't taken the time to pull it apart again.
joe
Old Feb 15, 2010 | 07:24 PM
jdpartsman's Avatar
jdpartsman
I removed my door panels, made notes on where I had metal vs nothing and used black shelf tapping screws. Now my door panel is screwed tightly to the door and is alot better now. This might not be a good idea for everyone, but it worked for me.
Old Feb 15, 2010 | 07:41 PM
dirtydog's Avatar
dirtydog
Moderate User
My door panels are covered with Dynamat on the inside. No vibrating from the bass and zero noise issue's as far as creaking but my truck is still fairly new.
Old Feb 15, 2010 | 08:18 PM
shadow11's Avatar
shadow11
My truck does the exact same thing! The only thing that squeaks in the whole truck is the drivers door panel. Also the door lock rattles too. Really annoying. Any body got any ideas!?
Old Feb 15, 2010 | 09:14 PM
bwheelersc's Avatar
bwheelersc
same here. any cheap Dynamat like padding that can be used??
Old Feb 16, 2010 | 04:27 PM
BadHab1t's Avatar
BadHab1t
bump for more ideas....come on guys if my truck needed a lift kit yall would be all over it like flies on chit....
Old Feb 16, 2010 | 04:40 PM
SilverBullet08's Avatar
SilverBullet08
u can use the cheap insulator or sound deadener(i think) from home depot?
