Going with wheel spacers.... wheel question
Old Feb 19, 2010 | 02:51 AM
98cherryram's Avatar
98cherryram
My lugs worked perfectly well with my 1/4 inch spacers, of course my lugs are aftermarket along with my aftermarket wheels... I have locking lug nuts...
Old Feb 19, 2010 | 08:57 AM
SMKNRAM's Avatar
SMKNRAM
Thanks 4.7! But there is only a 1/16" difference between 1/4 and 5/16. BUT 1/16 is alot when you are talking about stud strength. If you want to go wider, get a set of 1-1/4" bolt on hub centric spacers. That is what I am running on my truck, with no issues. no vibration nothing. I have double checked the torque on min several times and no issues there either. Definitely gives a more aggressive stance with stock wheels.
The stock 20's are 9" wide.....
Old Feb 19, 2010 | 09:20 AM
oefootball_70's Avatar
oefootball_70
I have 305/70/17 in the stock wheels and they measure out 12.5 I would not go wider with the 315's. Just my opinion. But you can do w/e you want. You will prob have terrible tread wear and thats always fun.
Old Feb 19, 2010 | 09:22 AM
oefootball_70
Oh, and my spacers came with a new set of lugs. So I no longer have the stock lugs. Just bolt looking lugs. O well they hold the wheels on.
I have 1.5 inch spacers.
Old Feb 19, 2010 | 02:16 PM
hoss67's Avatar
hoss67
Thanks dudes, actualy just got back from having my left lower ball joint replaced.... but anyways, i was reading about the 5/16 spacers from advance, i actually saw them, are they wide enough for the tires where they wont rub? and i will prob. go with 305/70/17's,
Old Feb 19, 2010 | 02:25 PM
oefootball_70
5/16, do they look like this?
if so don't do it
if they look like this
then you should be okay
Old Feb 19, 2010 | 02:31 PM
hoss67's Avatar
hoss67
yea the first ones can acutally bend ur lugs if u dont watch out, its the second ones....
Old Feb 19, 2010 | 02:41 PM
4.7Ram5.7Rango's Avatar
4.7Ram5.7Rango
Great info!! The first ones were the ones I was gonna get!!! Ya'll cats are awesome!!! Thanks!
P.S. Im assuming the second set are the "hub centric" ones Ive been hearing about?
Old Feb 19, 2010 | 02:43 PM
oefootball_70
fo sho
Old Feb 19, 2010 | 10:24 PM
SMKNRAM's Avatar
SMKNRAM
the 5/16 will not work, your factory studs will stick through and hit the back side of your wheel. you need at least 1-1/4" to cover the factory studs
