Bad bad sounds
Old Feb 26, 2010 | 11:15 PM
  #21
Shiloh 24's Avatar
Shiloh 24
Originally Posted by 08RamMan
Looks good. What did you use to seal it up?
RTV, I got the heat resistant red colored stuff. I saw that used in a DIY video a while back.
Old Feb 27, 2010 | 06:39 AM
  #22
Deviate's Avatar
Deviate
Looks like the same stuff that was on mine from the factory. When I changed my gear oil a couple of weeks ago I put a gasket that I bought from Napa in there instead. That RTV (assuming that is what they had on it from the factory) is a pain in the @$$ to clean off! So far the gasket is working fine with no leaks. We'll see how hard it is to clean off when I change the fluid again.
Old Feb 27, 2010 | 11:02 AM
  #23
Shiloh 24's Avatar
Shiloh 24
I'll have to look into that the next time I change it, sounds alot easier than messin with the RTV.
Old Feb 27, 2010 | 11:06 AM
  #24
abarmby's Avatar
abarmby
Try this next time when cleaning off the RTV.
Stuff some lint free rag into the diff/gear housing. Then, get a portable electric hand drill with a fine wire wheel attachment.
Use this wire wheel to scrub away easily the RTV. Takes about 5 mins total for both faces.
Clean up the faces of the cover and diff housing with brake cleaner and use high temp RTV to re-seal.
Hope this helps?
Al.
Old Feb 27, 2010 | 12:43 PM
  #25
Shiloh 24's Avatar
Shiloh 24
Hope this helps?
Al.
I'm gonna have to look into that too next time.
