cant remove upper a arm with pap emergency!!!
Old Feb 24, 2010 | 03:17 PM
Desert_Ram's Avatar
Desert_Ram
Default cant remove upper a arm with pap emergency!!!
hey guys im trying to put on my leveling kit on my 2wd and cant get that upper a arm to come off that spindle the pit man arm puller is literally digging into the spindle is there something im not doing right or a trick to it!
thanks guys
Old Feb 24, 2010 | 03:32 PM
Desert_Ram's Avatar
Desert_Ram
no body!
Old Feb 24, 2010 | 03:37 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
It it binding on the BJ. STOP now or ruin the BJ threads and replace it later.
Have you take the bottom BJ loose and everything else? Tie rod? Swaybar link? ECT?
cwboyjohnny24's Avatar
cwboyjohnny24
Try getting a pry bar and put it in between the spindle and the a arm. Pry on it while you hit the spindle at the joint with a BFH. Only hit the SPINDLE not the ball joint.
Old Feb 24, 2010 | 03:43 PM
dirtydog's Avatar
dirtydog
Moderate User
R u trying to separate the upper balljoint? is that the issue?
did you take the balljoint nut off?...lol is the pitman arm puller big enough? I'd take a few swifts with a hammer on a solid surface to separate them. i wouldn't go apesh*t on it as you may crack it unless your spindle isn't aluminum like mine? if it's cast, pount the crap outta it with a 3-5lb sledge.
I'd prefer pickle forks over a puller like your using. Easier and less damage.
Old Feb 24, 2010 | 03:44 PM
dirtydog's Avatar
dirtydog
Moderate User
ohh, and make sure you have the whole assembly supported underneath or that spring will shoot out and kill you.
Old Feb 24, 2010 | 03:47 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I ziptie my UCA and spindle together as I break it loose so it doesnt fly apart.
cwboyjohnny24
+1 on that. Try putting a jack under it. Mine's an 04 and it's cast. That's what i did. I pounded the hell out of it. His is an 03 so it should be cast too.
Old Feb 24, 2010 | 03:53 PM
Shiloh 24's Avatar
Shiloh 24
I jacked up the whole setup to where the spring was maybe halfway compressed, that way the balljoint wasn't at such an extreme angle and it popped easier this way. I used the pitman arm puller as well, I didn't compress the spring on the other side and I couldn't pop the thing loose. So I jacked it up like the other side and it popped as soon as I put pressure on it with the PAP.
Desert_Ram's Avatar
Desert_Ram
yes i have it all apart to the point that i need to get the upper a arm and spindle apart to removal the coil i have it supported with the jack under it just cant seem to get them apart haven't tryed a pickle fork yet cause i don't want to damage the ball joint!
