Repairing front plastic air dam
Old Mar 1, 2010 | 11:02 PM
WeightLifter500's Avatar
WeightLifter500
Default Repairing front plastic air dam
I did a search on this and really didnt find what i was looking for. I recently had one of the plastic holders "let go" on the right corner of the plastic air dam on the front of my 05 ram. It is the corner nearest the RS front tire and it the plastic piece that connects in the metal holder has snapped. What's the quickest way to fix it. I have considered bending it and then super-gluing it back up there, but i think it will rip the small plastic prong completely off then. Any help is appreciated.
Old Mar 1, 2010 | 11:12 PM
southernbnb's Avatar
southernbnb
mine came loose on the drivers side and i had to go to napa and buy a new bolt to screw in there. there should be a bolt that threads into a nut that is held onto the air dam by a metal clip. you may need to replace the clip and the bolt.
Old Mar 2, 2010 | 02:13 AM
KUhawkFAN's Avatar
KUhawkFAN
Ive ripped my whole air dam off offroading. Since you just have a corner thats bad, maybe u can just put a new bolt and nut through it. you wouldnt be able to see it, just a thought. i had to get a entire new one, luckly there only about 95 bucks on ebay, sorry if im not much help, hope u get it figured out
Old Mar 2, 2010 | 02:20 AM
Shiloh 24's Avatar
Shiloh 24
Chit, I ripped mine off a while back too tryin to climb a steep *** hill. Ended up comin back down backwards and the sumbitch was layin there on the ground in front of me. I tried reattaching it and gave up, it's been sittin in the bed of my truck for almost 4 months now.
Old Mar 2, 2010 | 03:05 AM
Marx's Avatar
Marx
i'd use a plastic epoxy it should do the trick
Old Mar 2, 2010 | 08:55 AM
korby05's Avatar
korby05
That's what I used on my and it's holding without any problems
Old Mar 2, 2010 | 09:01 AM
TRXHemi's Avatar
TRXHemi
Slip a ziptie through there....or remove it. Easy enough!
Old Mar 2, 2010 | 09:49 AM
AF_HEMI's Avatar
AF_HEMI
duck tape!!!
afterall, its holdin shiloh's truck together no problem!
Old Mar 2, 2010 | 10:40 AM
graphicjunkie's Avatar
graphicjunkie
If you want a 'metal fix' you have a couple of options. Since it's out of sight, you could take some plumbers tape and run a couple of strips along that edge, top and bottom, where the plastic ripped. drill holes and rivet it in place. Then you can reattach your metal bracket/screw bracket. OR you could take it a step further and put a bolt/nut through there. Doing this will also reinforce that lip for future possible rips. Dress it up further by painting the metal strip to match the plastic.
Those plastic pieces are made from polyurethane. They sell kits (autozone) that are like $13, which you can repair it back to original spec. Takes some time to do it, but the stuff works well. Just like an epoxy, it comes with two parts that you mix together then apply.
