3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Hey guys, I recently bought a truxedo original tonneau cover and the first week I saw some improvment but now it feels like my mileage went down. Did it decrease it instead of increase it or is it just now tight enough? Any feed back is great thanks.
I don't know if the same is true with a cover but I know they proved it on Mythbusters that you actually get better mileage with the tailgate up as opposed to being down. There is a special way that the air flows and circulates in the bed of the truck and when that airflow is lost it creates a drag, I'd assume a cover would have the same effect.
I'm thinking could it be the tension of the cover? Like if it's loose it causes air to go under it and causing a drag? When I drive I see it wave abit but I'm thinking that's just the soft top for you. Is it supposed to be super tight where it looks like a hard top or what?
Mine went up and mine weighs a ton... what type of driving have you been doing? If you see a lot of highway it should go up city will probably just even out
If it's gettin air underneath it your creating a crapload of drag, it's almost like attaching a giant stick on hood scoop to your hood and the air hitting and gettin caught in the scoop causes drag.
