Rack and pinion system (FAIL)
Old 03-12-2010, 11:25 AM
KrisKountry's Avatar
KrisKountry
KrisKountry is offline
Default Rack and pinion system (FAIL)
I have a 04 Ram 1500 with a 7" lift and 35" tires. I thought this was the cause of my rack and pinion system on my truck to fail. I was partially wrong. I have read of people with WAY less miles than mine having theirs fail. Which brings me to my questions......Is the system on a 2500 or 3500 built stronger? If so will it fit on my truck? If not any reccomendations as to where I can find one that is stronger and will fit my truck.
Thanks in advance
Kris
Old 03-12-2010, 12:07 PM
Bent's Avatar
Bent
Bent is offline
Mine (on a stock 03) pukes power steering fluid out one side of the rack when I cold-start the engine, it leaves a red spot on my driveway like it's the truck's time-of-the-month.
(But at least it's never cranky).
Old 03-12-2010, 12:44 PM
Beastro's Avatar
Beastro
Beastro is offline
The 2500 is a solid front axle dont know about the 3500 put pretty shure that has a solid front axle. I have look on the net for a beefer 1 but no luck
Old 03-12-2010, 12:58 PM
HammerZ71's Avatar
HammerZ71
HammerZ71 is offline
Dodge Forum Administrator
Welcome to the fabulous world of IFS trucks. You were partially right however, larger diameter tires with greater weight DOES in fact put greater strain on the rack as well as just about all other front end suspension components.
You pretty much are stuck with OE racks, either new or rebuilts...
Old 03-12-2010, 01:31 PM
dazed01's Avatar
dazed01
dazed01 is offline
I've had mine replaced already.
Old 03-12-2010, 02:12 PM
04_ramslt's Avatar
04_ramslt
04_ramslt is offline
Thats a nice truck you got there. I live in cove but have never seen you around before. A few of us local guys were thinking about doing a meet and greet. You should come
Old 03-12-2010, 03:12 PM
Pyro's Avatar
Pyro
Pyro is offline
I Beat Tetris
The SRT-10 Ram rack and pinion is much stronger than a stock 1500's and it will fit, if you can find one.
Old 03-19-2010, 11:17 AM
KrisKountry
I think I forgot to mention that it is a 2WD model..... I don't know if that changes anything with the 2500 or 3500 rack or not...
Old 03-19-2010, 11:20 AM
KrisKountry
I wou ld love to go to a dodge meet and greet, show off what I have done and give/get ideas from other trucks out there. That would be alot of fun. Let me know when and where this happens and I'll be there.
Old 03-19-2010, 12:13 PM
SilverBullet08's Avatar
SilverBullet08
SilverBullet08 is offline
i was just in austin on wednesday to pick up my hood lol
Quick Reply: Rack and pinion system (FAIL)
