How do you guys add diff fluids?
Old Mar 14, 2010 | 10:44 PM
AlbertaRAM's Avatar
AlbertaRAM
Default How do you guys add diff fluids?
So this weekend I decided to change my front and rear diff fluids (along with transfer case and the usual oil change). This was my first time changing them on this truck.
It sucks not having a drain plug or a normal gasket... but I can deal with that. But do you guys have any special funnels/pumps to make it easier to add in the new fluids? I'm sure my neighbours are scared of me after the swearing that came from my garage while I was trying to add the new fluid in using the funnels/etc I had!
Just looking to get some tips maybe on what works well so I can get one for next time
Oh and what's with the rubber plug?! Doesn't seem like a well thought out idea by Dodge haha!
Old Mar 14, 2010 | 11:00 PM
Shiloh 24's Avatar
Shiloh 24
On the diffs just pull the rubber plug and fill the oil level to just slightly below the fill hole. As for the transfer case I know nothing about it since I don't have one.
Old Mar 14, 2010 | 11:10 PM
AlbertaRAM's Avatar
AlbertaRAM
I know how do to it, that's not what I meant
I mean what do you guys use to get the fluids in without making a mess since there seems to be a ton of things in the way.
Old Mar 14, 2010 | 11:11 PM
senselesscreationz's Avatar
senselesscreationz
whats everyone running in the diffs? i know mine def have to be done after this weekend. i have a 4x4 if you didnt know
Old Mar 14, 2010 | 11:13 PM
AlbertaRAM's Avatar
AlbertaRAM
Using Amsoil myself.
Old Mar 14, 2010 | 11:14 PM
Shiloh 24's Avatar
Shiloh 24
I didn't use anything when I did mine, the tip on the Royal Purple bottle was long enough I didn't need to use anything and Senseless even though it wasn't cheap I put Royal Purple in mine.
Old Mar 14, 2010 | 11:15 PM
bwheelersc's Avatar
bwheelersc
I used a funnel that has screw on caps on both ends, worked awesome with no spills. No idea where it came from, used one from work.
Old Mar 14, 2010 | 11:17 PM
AlbertaRAM's Avatar
AlbertaRAM
Wouldn't happen to have a pic would you?
Old Mar 14, 2010 | 11:21 PM
senselesscreationz
steer me in the right direction just get royal diff fluid or is there a special bottle to get? and haw many bottles per diff? which means how many total. man i hate not knowing some shlt really sucks
Old Mar 14, 2010 | 11:28 PM
bwheelersc's Avatar
bwheelersc
[IMG]file:///C:/DOCUME%7E1/oke11241/LOCALS%7E1/Temp/moz-screenshot.png[/IMG]something like this:
http://www.cleanfunnel.com/introfromstore.html
