April 3rd gen OTM
Old Mar 25, 2010 | 08:45 PM
  #221
SMKNRAM's Avatar
SMKNRAM
super bitchin!!
Old Mar 25, 2010 | 08:48 PM
  #222
ramhunter9's Avatar
ramhunter9
frog is bitchen!!!! rock on brother
Old Mar 26, 2010 | 12:20 PM
  #223
RubberFrog's Avatar
RubberFrog
Originally Posted by Bluesmanjesse
PM me if you need any electrical help, I'm an electrician I'll point you in the right direction if I can.
I appreciate that!
And for the record, you guys are bitchin!
Old Mar 26, 2010 | 04:20 PM
  #224
jk360's Avatar
jk360
same here Frog. need any help or have any questions let me know.
Old Mar 26, 2010 | 05:45 PM
  #225
RubberFrog's Avatar
RubberFrog
I wish you guys were closer. I have an old pushmatic box. If you're not familiar with them, they don't use modern snap in breakers. The breakers are screwed in. It's in fantastic shape so I have no plans to change it, but it has no master disconnect. That means when I install the new breaker it will be live as I'm screwing it in! Pray for me.
Old Mar 26, 2010 | 06:07 PM
  #226
AF_HEMI's Avatar
AF_HEMI
why dont you just replace the box? they're cheap... like $100 for a 100amp service (which is all you need in a garage anyway being that its most likely a branch off the primary box in the house)
Old Mar 26, 2010 | 06:14 PM
  #227
RubberFrog's Avatar
RubberFrog
It's the box in the house I am referring to!
  #228
ramhunter9's Avatar
ramhunter9
i will pray for you ...if you do get burned and cooked i want your legs ....mmmm frog legs
Old Mar 26, 2010 | 06:28 PM
  #229
AF_HEMI's Avatar
AF_HEMI
you can have his legs... i want his truck!!!
either way, the upgrade is cheap george. is it worth the $200 or less to not zap yourself with the entire service? God help you if you touch that main service wire... i promise you'll be seein stars and wondering where you are. 110v is a tickle... that main feed will literally throw you a few feet
Old Mar 26, 2010 | 06:32 PM
  #230
RubberFrog's Avatar
RubberFrog
I can't change the box any easier than changing the breaker- I have no master disconnect.
