2wd to 4wd
Old Mar 24, 2010 | 04:32 PM
Moparich's Avatar
Moparich
Default 2wd to 4wd
so im looking to swithc my 08 ram to a 4wd. it looks liek the hubs are set so where can i find a transfer case and front diff. also please add any comments you 4wheelers.
im movin to utah in june and will need the 4wd drive come winter and summer i guess for trails. but would like to keep my ram as its paid for and its still does the duty of towing my 70 charger to and fro the track
thanks in advance
Old Mar 24, 2010 | 05:04 PM
Matt99's Avatar
Matt99
Everyone will jump in and say just trade yours in for a 4x4...and I agree with them.
Its not just a transfer case/front diff...you have to get the axle, cv axles, front suspension setup is a bit different on 07 2wd/4wd. The switches, different flash im sure, make sure you match the rear gears
IF you could find an 06-08 that was totaled maybe you could buy it and use it as a donor, but with the way these trucks are set up (computer) its just a real big deal. You would probably be out over 3k with all the parts, not including labor, and if you traded your truck on one you might be out 2-3K (depending on your truck)
Old Mar 24, 2010 | 05:07 PM
ramhunter9's Avatar
ramhunter9
i agree with mat on this one , its just cheaper to trade
Old Mar 24, 2010 | 05:17 PM
glass3222's Avatar
glass3222
It is much easier and cheaper to trade it in on a 4x4.
I helped converted an old (72) chevy to 4x4. It was a ton of work to do and do right. It also takes a lot of time. And it did not have computer controlled anything to worry about and we did a solid axle.
Old Mar 24, 2010 | 05:22 PM
RedTruck-VA's Avatar
RedTruck-VA
It is just not practical to make the conversion with the way everything is tied to the computers. You would have to have the entire electrical system tranplanted into your truck and the cost of that alone would buy you a nice 2nd hand 4x4.The construction/trouble shooting time would be lengthy to say the least. I have to say do try it. Good luck..
Old Mar 24, 2010 | 05:50 PM
Markmm0000's Avatar
Markmm0000
prob a different frame
Old Mar 24, 2010 | 06:18 PM
Gone Fishin's Avatar
Gone Fishin
Yup,
All of the above ^^^^^
I also believe you'd have to change out the tranny for the transfer case setup, or get a whole new tail shaft housing. If you use a donor, then you got to get rid of the rest of the truck as in scrap it ot part it out. The interior controls would require a new center for the manual engagement or the wiring and computer flash for the push button engagement.
Lots of them around, just do your homework before you decide to dive in. I'd guess you'd be looking at substatially more than 3-4 G's for the change, after it's all said and done.
You may have to have the type truck changed on the registration too--not sure on that, but wouldn't doubt it.
Old Mar 24, 2010 | 07:32 PM
HammerZ71's Avatar
HammerZ71
Everyone I know who's looked seriously into it (and even the mechanics who could do all the work themselves) have turned tail and just traded for a 4x4.
