Front oil seal leak
Old Mar 24, 2010 | 10:34 PM
whiteram05's Avatar
whiteram05
Default Front oil seal leak
Hey guys, anyone change out their front oil seal on the crank? The repair manual does not make it seem very difficult. I know I can change it, but I would like to hear about your experience.
Old Mar 25, 2010 | 07:35 PM
chambers's Avatar
chambers
It's no big deal as long as you have a huge socket to tap the new seal in, I had to buy one which was about $50. As long as you have the right puller for your pulley and the big socket it will go smoothly, I only had to take off the back part of the shroud to do it all (the part that has 4 screws holding it on). I got the new seal from NAPA but later found out that it's probably cheaper at your local dealer, how bad is yours leaking?
Old Mar 28, 2010 | 11:52 PM
whiteram05's Avatar
whiteram05
It is not really that bad yet. Leaves spots on the drive, but it seems to be getting worse. I am waiting for the weather here to warm up just a bit first on the coast before I change it out.
Old Mar 29, 2010 | 05:50 PM
chambers's Avatar
chambers
Ok, I did mine in my dad's garage so I didn't have to worry about the weather. The manuals say you need to take off the whole shroud and radiator, but I did it by just pulling the shroud extension off that's held on w/ 4 screws. The pulley has always been the worst part for me b/c out of the 2 times I've pulled it, both times I had the wrong puller.
Old Mar 30, 2010 | 11:25 PM
whiteram05's Avatar
whiteram05
My biggest concern is that I would damage my pulley. I don't want to have to buy another one. I just put this thing on last year or so.
Old Mar 31, 2010 | 06:36 PM
chambers's Avatar
chambers
Yea, when you go to get the puller just take it out before you leave and make sure it will work w/ the pulley. We had to pry mine off b/c my dad didn't listen to me about how to use the puller and rammed part of it straight into where the crank bolt goes, then we had to get that out after we got the pulley off .
Old Oct 26, 2012 | 05:19 PM
whoamioitsi's Avatar
whoamioitsi
Thanks for the info on this issue I am in need of doing mine
can you give me a idea of the puller i need ? just your normal 3 jaw puller ??
or will i be needing one with a special thread to go in the pully ??
Old Oct 27, 2012 | 10:07 AM
chambers's Avatar
chambers
It's a standard 3 jaw puller nothing special.
Old Oct 27, 2012 | 05:39 PM
whoamioitsi
sweet thanks Chambers thats what i was hoping to hear I happen to have a few of them kicking around in the shop
