Kinda concerned here...
Old Mar 26, 2010 | 07:54 PM
Ice-Forever's Avatar
Ice-Forever
Default Kinda concerned here...
Alright guys, so today I was driving around w the windows down and I thought I had heard something so I turned down my music to listen for anything...
When I'm accelerating I hear a obnoxious noise. It's not REALLY loud or anything, and I don't really know how to describe it...It's not really a grinding or anything, it sounds almost like a squeal and I thought it might be a belt or something...However, it sounded like it might have been coming from underneath my truck...
The noise only happens when I am in drive and floor it. If I just accelerate normal there is nothing, or if I am in park and rev the engine up. But if I'm in drive and floor it I hear the noise. I was worried that it might be the drive shaft or something...?
Old Mar 26, 2010 | 08:01 PM
OICUDRIVE12's Avatar
OICUDRIVE12
Idk for sure but I would start with the Tranny.
Check the fluid and see if it looks or smells burnt, and ofcourse make sure your not low.
Then if it looks clean and checks out move to the rear diff. Look for gunk, and wear and tear.
Old Mar 26, 2010 | 08:03 PM
Ice-Forever
I was really afraid that it was the rear diff as well, but why would it only do it when the truck is at WOT?
I'm gonna go check the tranny fluid right now.
Old Mar 26, 2010 | 08:06 PM
ramhunter9's Avatar
ramhunter9
there should be a greese zert on your drive shaft check that it is lubed .
Old Mar 26, 2010 | 08:10 PM
95_318SLT's Avatar
95_318SLT
Sounds like a pinion bearing on its way out. Read this and see if it sounds like your problem...
BEARING NOISE
The axle shaft, differential and pinion gear bearings
can all produce noise when worn or damaged.
Bearing noise can be either a whining, or a growling
sound.
Pinion gear bearings have a constant-pitch noise.
This noise changes only with vehicle speed. Pinion
bearing noise will be higher because it rotates at a
faster rate. Drive the vehicle and load the differential.
If bearing noise occurs the pinion rear bearing is
the source of the noise. If the bearing noise is heard
during a coast, front bearing is the source.
Worn, damaged differential bearings usually produce
a low pitch noise. Differential bearing noise is
similar to pinion bearing. The pitch of differential
bearing noise is also constant and varies only with
vehicle speed.
Axle shaft bearings produce noise and vibration
when worn or damaged. The noise generally changes
when the bearings are loaded. Road test the vehicle.
Turn the vehicle sharply to the left and to the right.
This will load the bearings and change the noise
level. Where axle bearing damage is slight, the noise
is usually not noticeable at speeds above 30 mph.
OICUDRIVE12
Well not sure why it would only do it when your WTFO but u can never be to carefull.
But if the diff. is waterlogged or chunked it may make to noise all the time at steady speed but you can only hear it when its under some heavy pressure.
Plus u said it did not make the noise when the truck is at idle or reved in N or P, so it sounds like its in the gears somewhere just gotta narrow it down.
Old Mar 26, 2010 | 08:13 PM
Freakinkeith806's Avatar
Freakinkeith806
Ouch, hope its nothing too major.
Old Mar 26, 2010 | 08:16 PM
Ice-Forever
I got under there and the shaft looked a bit dry so I was hoping that it just needed some grease put on it, but I wanted to post just to make sure.
Where do I put the lube at? I saw like 5 diff spots that could be.
Also, I checked the tranny fluid and it smelled alright. Wasn't sure at first so I pulled my moms dip stick out of her car and smelled hers then smelled mine to make sure and they smelled the same lol.
95, there is only a noise at WOT. I don't really know how to describe it and I'm sure as hell not gonna go cause it to happen again just so I can hear it to describe. It didn't sound like a grinding, it kinda sounded like a belt, like almost a kind of squeaking noise.
Old Mar 26, 2010 | 08:19 PM
OICUDRIVE12
Grease all of your fittings, a little lube wont hurt her.
Old Mar 26, 2010 | 08:23 PM
truckin151's Avatar
truckin151
Check all the hangers on your exhaust setup, could also be something inside the muffler is going to and is just rattling around.
