need reverse sensor wire location. URGENT
Old Mar 27, 2010 | 12:50 PM
jerzey111's Avatar
jerzey111
Default need reverse sensor wire location. URGENT
hey guys, im getting ready to install backup camera but my hu needs to hook into reverse sensor wire. Does any1 of you know the location of it by the dash??? i really dont want to run it to the taillights.
Thanks
Old Mar 27, 2010 | 12:57 PM
dirtydog's Avatar
dirtydog
Moderate User
On my 2008, i tapped into the reverse wire under the hood. it was a white/lt green stripe in the cluster of wires between the battery and the firewall.
You can prob take the lower half of the colum molding off and see if there is that wire and probe before splicing into it.
Old Mar 27, 2010 | 12:58 PM
FireFighter's Avatar
FireFighter
From: The old famed Gen3 Broken Valve Spring Thread - https://dodgeforum.com/forum/3rd-gen-ram-tech/237316
Not sure how much the '06 will differentiate, looked in my Haynes for 02-05, it shows a BRN/GRN from the back-up lamp switch to the 15A # 38 Fuse. You may be able to trace from the switch to under the dash...which prolly be a real PITA. Good luck
Old Mar 27, 2010 | 01:04 PM
jerzey111's Avatar
jerzey111
thanks guys, i just found wiring diagram for 06 and it also mentions white/lt green so it looks like 06+ are different.
Thanks again guys
Old Mar 27, 2010 | 01:07 PM
FireFighter
Welcome...have fun
Old Mar 27, 2010 | 05:39 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
I also tapped mine at the PCM wiring under the hood on the pass side firewall
Old Mar 30, 2010 | 10:38 AM
nicholoff's Avatar
nicholoff
everytime i do one i grab it from the reverse light. kuz i am already running wires back there.
Old Mar 30, 2010 | 11:35 AM
jerzey111's Avatar
jerzey111
Thanks guys it went much quicker w/ your help. Heres couple of pics
Old Mar 30, 2010 | 11:39 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
interesting placement. Good idea
Old Mar 30, 2010 | 11:56 AM
jerzey111's Avatar
jerzey111
i tried different spots like u guys have but i think this works the best here, perfect for parallel parking specially for getting into tight spots here in nj
