Push button start wishful thinking???
i guess donimiontx took his videos off of youtube. but he had one that showed his setup when he was done. it was sweet.
this is where he got the push start/off set up at. there are other places to do the same.
http://www.digitalguarddog.com/
here is a video of his old truck one of my favorites and his new alarm system after it was broken into. best idea yet
http://www.youtube.com/watch?v=cOGdfDZDYes
holy hell you mean im not the only one. whoa my reality is effed. thanks man. im around here every other week. ill be goin to okc in a month or so maybe a mini gtg is in order?
If you want the air horn to go through the trucks OEM security system then simply take the wires that go from the horn behind the D/S headlight and wire them into the two wires on your air valve for your horns. This way you can use they OEM keyfob or the horn switch in the steering wheel.
If you wanted to get creative you could use a 3-way toggle switch (On-Off-On) to flip between the OEM horn and the air horns.
Thats how i have my air horns hooked up. I was hoping when you lock the doors with the keyfob it was blow the horn but the chirp isnt long enough to open the selenoid up all the way so it really doesnt make a sound.
