CAI help
Old Apr 2, 2010 | 07:05 PM
  #31
Cherokee's Avatar
Cherokee
Originally Posted by 04_ramslt
Not trying to hijack a thread but Ive been looking at making an intake on my truck and was wondering what size diameter piping everyone is using and what made you choose that size. And again im not trying to hijack the thread.
I would also like to know what materials are needed to make a DIY CAI.
Old Apr 2, 2010 | 07:31 PM
  #32
Beastro's Avatar
Beastro
Originally Posted by weedahoe
that much pipe is sure to absorb a lot of engine heat..........
what if you wrap the pipe with heat wrap for exhaust?
Old Apr 3, 2010 | 01:07 PM
  #33
Busdriver9's Avatar
Busdriver9
I used 3" PVC(that is the diameter of the TB) It dosent take much at all, I got 1-24" PVC and 3-elbows from hardware store.
Old Apr 3, 2010 | 01:12 PM
  #34
Albertaramfan's Avatar
Albertaramfan
I agree the vararam looks sweet but didn't suit my driving habits when I used to 4x4.
The Volant is goin to be sittin on the shelf soon anyways when I order up my twin turbo kit.
Those of you looking for a diy go into the faqs for the 3rd gen and theres a write up in there
Old Apr 3, 2010 | 01:43 PM
  #35
Busdriver9's Avatar
Busdriver9
Talking materials list for CAI
I used:
1- 24" piece of 3" PVC (cut into a few sizes)
3- 45 degree PVC elbows
1- PVC cement
1- 1" to 3/4 adapter for a hose (I just found this part by mistake but it worked better than what I had imagined)
1- air temp sensor(you can get the one out of the HEMI hat but I wanted to buy one so I can return my stock air box if need be)
1- 3 1/2" high flow cotton fiber air filter (NOTE:3" PVC is actually 3 1/2" on the out side, 3" inside.
1- 3" coupling for PVC to TB.
*take my advice take your time when cutting your PVC and cut it straight*
Old Apr 4, 2010 | 06:52 PM
  #36
05DodgeRamHemi's Avatar
05DodgeRamHemi
Idk...something just strikes me odd about plumber's hardware installed on my truck. I am just fine with my factory airbox until I can afford a kit, that's just me though.
Old Apr 4, 2010 | 08:22 PM
  #37
lxman1's Avatar
lxman1
Site Moderator
Originally Posted by foxxx665
i spent the money and put a volant on my 03 ram, which is bored .030 over and stroked, camed and to much others to list i have around 10k in the motor and tranny and it puts out 470hp. but the volant came with a upgraded mass air flow sensor and be sure not to put that K&N oil on your filter cause it will suck into the intake tube and mess up the mass air flow sensor and cause a code on the computer. that is what happened to my future father in laws 05 ram when he went cheap and tried to compete with my ram rod truck. DO YOUR HOME WORK.
You must have the only Ram ever built with a MAF because Dodge uses a speed density system and there is no Mass airflow sensor.
Old Apr 4, 2010 | 09:17 PM
  #38
crazyandy202's Avatar
crazyandy202
Hey Busdriver9 could you post a picture I really want to see your setup!
