DIY Tranny Line Pressure Booster
sharkhunter10.
Did you purchase a Sonnax plug or, did you do the mod by wirring it up yourself?
The reason I ask is OlDirtyJohn has had build quality issues, in his Sonnax plug.
Very poor workmanship and crimping etc, found in it.
PM him and I'm sure he'll tell you what he found in his Sonnax plug.
Could this have caused your transmission problem?
Al.
Al.
I dont think the 02s have the TMR. Only the 03 does because it has the 545rfe and a separate PMC and TCM whereas anything later has them both integrated into one.
The resistor (AKA power wire) on the IAT sensor wire has nothing to do with the TMR or Sonnax. These are two different devices on two different components that do two different things.
