spark plug help
Old Apr 2, 2010 | 02:04 PM
4matty3's Avatar
4matty3
Default spark plug help
my socket is stuck in the hole and wont come out. i cant get to it because the stupid brake booster is in the way. can i take the booster off or how else can i can the socket out.?
Old Apr 2, 2010 | 02:19 PM
JoeHemi's Avatar
JoeHemi
you talkin about the long 5/8ths spark plug socket? If you have a small adapter or extension, you can put that down the hole and snap the two together and then pull it out
Old Apr 2, 2010 | 02:20 PM
4matty3's Avatar
4matty3
the plugs all the way to the top tho
Old Apr 2, 2010 | 02:31 PM
JoeHemi's Avatar
JoeHemi
ah I see what you are sayin. You may have to lay on the engine and reach in with both hands and try to shimmy it loose or something. I know the booster is removable, I just havnt done it myself. Here's what the manual says about removing the booster if you need the info.
Old Apr 2, 2010 | 02:57 PM
nateroach's Avatar
nateroach
why not use a magnet? the head are aluminum so it should just grab the socket right?
Old Apr 2, 2010 | 03:00 PM
BadHab1t's Avatar
BadHab1t
honestley i use 2 sockets when i do mine because of that....i have a socket the plug fits nice in to remove and one the plug fits in loose for install....not all people have a few laying around but if yopu do id try that...or yes a magnet should work....
Old Apr 2, 2010 | 03:33 PM
ramhunter9's Avatar
ramhunter9
i love changing plugs
Old Apr 2, 2010 | 03:54 PM
FireFighter's Avatar
FireFighter
From: The old famed Gen3 Broken Valve Spring Thread - https://dodgeforum.com/forum/3rd-gen-ram-tech/237316
x100 on these trucks! Gotta have the 2 different sockets. Actually, I had 4 but 2 of them found the rapid propulsion method to the mountian stream the 1st time I changed plugs on this truck
Hey Joe, where did you get that cool schematic from?
Old Apr 2, 2010 | 05:03 PM
4matty3's Avatar
4matty3
i got it thanks guys. i put a screw driver in and shimmied it out although the magnet with a long pole would have worked great. these things are a pain in the ***. Do you guys use a 6inch extension or 3"? im using the 6 right now but am having trouble with it being too long, and im not sure if the 3 is long enough?
Old Apr 2, 2010 | 05:07 PM
abarmby's Avatar
abarmby
Try and get a long piece of wooden dowel.
Put some epoxy resin glue on it and tag it to the socket.
Make sure it's not run onto the plug top.
Let it set, then try to pull the socket out????
Only thing I can think of, if a powerful magnet doesn't work.
Strike that....just read your successful attempt.
Al.
