Un-labeled switch in my '07 1500
Old Apr 4, 2010 | 03:04 PM
havokblue's Avatar
havokblue
Default Un-labeled switch in my '07 1500
I just bought a used Ram yesterday and I found this random on/off switch to the bottom left of the steering wheel down by the parking brake. In the owner's manual it is described as a way to adjust the pedals, but it is quite clearly not considering it is simply on/off.
Anyone know what this is? My dad thinks it might have something to do with passenger airbags, but I doubt it.
EDIT: Here's a picture.
https://i.imgur.com/oPQLO.jpg
Old Apr 4, 2010 | 04:04 PM
havokblue's Avatar
havokblue
Added a picture
Old Apr 4, 2010 | 04:11 PM
kvsmith2004's Avatar
kvsmith2004
Could have been for something aftermarket from the previous owner, I know my light behind my grill use a switch like that just mounted in a different place.
Old Apr 4, 2010 | 04:17 PM
oefootball_70's Avatar
oefootball_70
Thats aftermarket. Wait until tonight and flip it on and off. See what happens.
Old Apr 4, 2010 | 04:18 PM
WhiteRamTRX4's Avatar
WhiteRamTRX4
On my ram, that space is just a cover, no on/off switch. It doesn't look stock to me so as others have said, probably for some lights that were removed. That or maybe some LED lights under the dash...that's what I'll be doing soon
Old Apr 4, 2010 | 04:24 PM
havokblue's Avatar
havokblue
It doesn't seem to be anything with the lights. I just went and flipped it on/off at different stages of lights being on. Nothing changed. Albeit it's 3 in the afternoon.
I doubt it's audio related. No subs and the stock stereo is in.
Old Apr 4, 2010 | 04:27 PM
kvsmith2004
DO you have any wires coming off your battery terminals? I would bet its something aftermarket that has been removed. If you can trace the wires down, if they are there behind the switch you are pre-wired for something you may want to install, like lights!
Old Apr 4, 2010 | 04:30 PM
ramhunter9's Avatar
ramhunter9
put a meter on it see if its hot ...then trace the wires
havokblue's Avatar
havokblue
I'm pretty sure there are wires to the switch. I can't tell cause it's a pretty hard angle to see. I'll go check the terminals and see if I see anything.
Old Apr 4, 2010 | 04:38 PM
havokblue's Avatar
havokblue
There are some wires coming off the terminals. Whether or not they should be there, I have no idea. So I'll let you tell me!
https://i.imgur.com/RDNis.jpg
And I unfortunately don't have a meter to see if the switch us live.
