bushing squeeking - what kind to get?
Old Apr 4, 2010 | 10:40 PM
JOHNSN10's Avatar
JOHNSN10
Default bushing squeeking - what kind to get?
so i have a squeek that i think are the bushings so i want to replace them. i searched bushings on ebay and found ones for the sway bar and suspension control arms.im gonna just replace all of them since they are cheap enough.what kind or make do i wanna get? anyone have a link to the ones i should get?
Old Apr 5, 2010 | 12:11 AM
OlDirtyJohn's Avatar
OlDirtyJohn
check out energy suspension. they have a lot of universal bushing that will fit the truck. and you can pick some of them up at your local autozone.
Old Apr 5, 2010 | 09:46 AM
hoss67's Avatar
hoss67
Make sure its not ur shocks, i had a squeaking noise from my front before, thought it was a bushing and turned out it was my strut/shock
Old Apr 5, 2010 | 09:53 AM
JOHNSN10's Avatar
JOHNSN10
I already got new shocks,squeekinf is still there.
Old Apr 5, 2010 | 09:55 AM
hoss67's Avatar
hoss67
ight check ur ball joints too, just incase ya know.
Old Apr 5, 2010 | 10:30 AM
dirtydog's Avatar
dirtydog
Moderate User
Poly busings will also make your truck handle butt loads better, but you will feel more bumps on the road.
When does the squeek/s happen? My mustang had squeeks and it was actually the outer tierods that were squeeking from being dry.
Old Apr 5, 2010 | 12:28 PM
JOHNSN10's Avatar
JOHNSN10
It makes noise when going over any kind of bumps but some days it wont make noise at all. Its just an annoying sound
Old Apr 5, 2010 | 12:31 PM
nim81's Avatar
nim81
if you get new bushings, before you install them apply some motorcycle chain lube to them. helps get them on and makes them squeak resistant!
Old Apr 5, 2010 | 01:02 PM
hoss67's Avatar
hoss67
i have had a squeaking noise, and its not the stuts ball joints and the bushing should be fine, and also my tie rods are bad, u think that could be a squeak? it squeaks over the bumps, but when i pick my tuck up and rock it myself it dont squeak at all....
Old Apr 5, 2010 | 01:47 PM
BadHab1t's Avatar
BadHab1t
2 words energy suspension....
