Extremely annoying noise Help
Old Apr 6, 2010 | 05:21 PM
bchap05's Avatar
bchap05
Thanks for the help. If I can figure out if its coming from the steering for sure I'll give it a shot. I think I might just have to lay on the floor and have wife drive around while try to find where its coming from. Probably not the safest method but when it won't make the noise unless moving I don't have much choice.
Old Apr 6, 2010 | 06:29 PM
matthewbeard's Avatar
matthewbeard
if that doesn't work might take it in to a shop you trust and see if they can't figure it out
Old Apr 6, 2010 | 06:40 PM
Albertaramfan's Avatar
Albertaramfan
Originally Posted by hoss67
could u explain that a little better for me so i can try it? i sure appreciate it
This lil fella right here
Even after adjusting it up I notice it settles back down and starts making noise again. Your's probably wont but between my steel hood and metal grill they're supporting a lot of weight
Old Apr 6, 2010 | 07:55 PM
hoss67's Avatar
hoss67
Dude thanks for the Pic! that awesome
Old Apr 6, 2010 | 08:16 PM
Albertaramfan
No problem! Let me know how it turns out for ya. I hope that's your issue and not something bigger.
Old Apr 6, 2010 | 11:39 PM
hoss67's Avatar
hoss67
i got some good news and bad news! bad news is it aint that lil fella i think its my other strut this time......... the goods news is, i actually got some extra cash to fix it!! haha
Old Apr 23, 2010 | 12:56 AM
bchap05's Avatar
bchap05
I finally figured out the stupid noise. It really sounded like it was coming from the dash so I laid down on the floor while my dad drove to try to find the exact location. Once I laid on the floor I could easily tell it was from under the truck not the dash. I went under and tightened my PA body lift blocks and it shut up.
Old Apr 23, 2010 | 06:21 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
My truck has developed a small squeak when I stop and start. I could tell it was coming from the rear. I ended up sparing some PB Blaster on my shackles and it went away. I know it will come back but at least I know where it is now so i can fix it.
Next time you should do the same and spray your bushings and front end pieces to help locate the issues.
Old Apr 23, 2010 | 07:49 AM
Tazman40's Avatar
Tazman40
My front struts made a noise like this.Took me weeks to find it,drove me up a wall.I could get out and shake,bounce,do anything and couldnt hear ir untill i drove.Finally i seen the oil all over the struts and had them replaced and all the noises went away.Squeks and clicks suck to pin point.Ide rather have the motor blow up,at least then ya know what it is.I have a piece of trim in the cab makeing a noise now and i have yet to find what it is.I guess thats why radios go so loud.just to drowned out the noises
