Who says the 03's arent tuneable??
Old Apr 10, 2010 | 10:04 PM
  #71
truckin151's Avatar
truckin151
Originally Posted by Off_Road_Teacher
It doesn't look slow man, best I could figure it looks like 0-60 in about 7 which is good for such a heavy truck.
Right it is fast for the size/weight, Im not denying that but by comparing it to what I know which is what mine does it seems a little slow for what that cam can do. Looking at a 7 second (+/-) 0-60 and comparing it to mine which does 0-60 in about 5.4sec it just seemed a bit slow is all.
Old Apr 10, 2010 | 10:11 PM
  #72
AF_HEMI's Avatar
AF_HEMI
I'm probably almost 1000 lbs heavier than you and have about 40lbs on each corner in unsprung weight. unsprung weight is 4 times as hard to move as sprung weight (40 lbs on each tire is 160 lbs unsprung, which has the same effect as carrying 640 lbs in the bed).
Gimme a break guys, this thing isnt even fully tuned yet. "It seems a little slow for what that cam can do"... yeah you're right. You're also not supposed to be able to run this cam in this truck.
Old Apr 11, 2010 | 01:28 AM
  #73
cheapbeater's Avatar
cheapbeater
looks like that somebitch is hauling to me...
i will join "the forgottens"
Old Apr 11, 2010 | 01:35 AM
  #74
AF_HEMI's Avatar
AF_HEMI
welcome aboard, you're number 5
Old Apr 11, 2010 | 01:56 AM
  #75
03MopaRamman's Avatar
03MopaRamman
AF Your probably way faster than you think! When you settle in your tune and get your foot pedal right you'll be real happy and well under seven seconds.
