TPS maxxed out at 86%??
Old Apr 9, 2010 | 01:56 PM
Albertaramfan's Avatar
Albertaramfan
Default TPS maxxed out at 86%??
So I was running some engine stuff on my superchip and noticed that my TPS shows a max of 86%...
Is this normal?
I've tried resetting the sensor with Teahes DIY and I literally just came inside from leaning the throttle body which was pretty gummed up but is there something else I should do?
Old Apr 9, 2010 | 02:09 PM
RubberFrog's Avatar
RubberFrog
Don't confuse % with degrees. 86% has it open all the way. If the throttle moved anymore, it would start to close in the opposite direction. Confusing, I know.
Old Apr 9, 2010 | 02:11 PM
Albertaramfan
That actually makes perfect sense. Thanks for the quick reply too.
Old Apr 9, 2010 | 02:15 PM
Blacksport's Avatar
Blacksport
Is this normal?
I tried searching for that DIY, but I can't find it. Could you help a brother out?
Old Apr 9, 2010 | 02:22 PM
Albertaramfan
Here's the links
https://dodgeforum.com/forum/3rd-gen...y-hemivec.html
https://dodgeforum.com/forum/3rd-gen...procedure.html
Old Apr 9, 2010 | 02:33 PM
Blacksport's Avatar
Blacksport
Thanks man!! Should I recal before or after the TB cleaning? Prolly after,eh?
Old Apr 9, 2010 | 02:35 PM
Albertaramfan
I would think it make sense to do it after. I'm gonna do mine again now that it's cleaned. I really recommend using an old toothbrush for cleaning the tb. Sure made my work easy (whole job took maybe 15mins)
Old Apr 9, 2010 | 02:41 PM
RubberFrog's Avatar
RubberFrog
I use my mother-in-laws whenever she visits.
Old Apr 9, 2010 | 02:53 PM
Albertaramfan
Whoa Frog! I meant to clean the TB not for use as TP! lol
Old Apr 9, 2010 | 05:37 PM
rickof08's Avatar
rickof08
mine max's at 78% according to superchips, I even had a friend manually hold the throttle open all the way to confirm.
