plugs
go to sparkplugs.com and use DT10PLGS and type in all the info and they give u right gap if u need plugs. as far as tools, i used 5/8 socket with a 3 inch extension. i picked up a ratchet where the head moves for different angle
make sure u get a magnet thing http://www.google.com/products/catal...d=0CB8Q8gIwAw#
dont forget anti seize and that de electric stuff or w.e
make sure u get a magnet thing http://www.google.com/products/catal...d=0CB8Q8gIwAw#dont forget anti seize and that de electric stuff or w.e
I got my 5306 plugs from www.moesperformance.com like $45 shipped to my door. Cheaper than AutoZone.
i got them all without taking off the brake booster. sometimes tho i had to hold the socket in one hand, and the extension in the other, then put the socket in the spark plug hole and the attach the extension to clear the brake stuff. NOTE this is for my 04 hemi with 16 plugs. so mine could be different.
Good Plug Choice - Moes also has a good description vs application on all those NGK's.
Coil Bolts use a 1/4 Ratchet with deep socket (8mm?) and be careful when re-installing (I like to Torque them to In/Lb Spec (small aluminum thread).
how you take off the black screw all way by brake booster
