Question about fuel gauge?
Old Apr 18, 2010 | 10:19 PM
Pruitts Hemi's Avatar
Pruitts Hemi
Question Question about fuel gauge?
Alright here's the deal.I have an 03 ram 1500 with the hemi in it. After feeling up with gas and driving about 30 or 45 minutes my gas gauge went to empty and the light came on.I know tank was full.This happenend twice.Both time it was around 30 or 45 minutes worth of driving.To be more specific i was driving down the interstate so it wasnt start and stop driving.Would really like some help or know if anyone else has had this problem and know what it might be.After i turned my engine off and then started it back up the gauge went back to normal again.Thanks for the info in advance if yall have any.
Old Apr 18, 2010 | 10:58 PM
TangledCable's Avatar
TangledCable
Sounds like maybe loose electrical contacts somewhere in the circuit. Intermittent problems like that are hard to diagnose but if it keeps up you may wanna go after fuel level sender and definately check over wiring for shorts to ground or opens.
Old Apr 19, 2010 | 01:19 PM
Pruitts Hemi
Thanks i will try that.If anyone else has anything to add please do.
Old Apr 19, 2010 | 03:28 PM
Pyro's Avatar
Pyro
I Beat Tetris
Either faulty wiring, faulty floater or faulty sending unit in the tank, assuming your other gauges are working fine that pretty much eliminates pcm/dash wiring faults.
Old Apr 19, 2010 | 03:39 PM
rocket23's Avatar
rocket23
love the gun control quote; Hate the signature pic. btw.
Old Apr 19, 2010 | 04:13 PM
Pruitts Hemi
Pyro.My oil pressure gauge was messing up on start up it would show no pressure.Turn it off and back on and back to normal.Guess i need to take it some where to check out dash wiring faults.
Old Apr 19, 2010 | 04:31 PM
Pyro's Avatar
Pyro
I Beat Tetris
Pruitts, I'd run down the other possibilities first, they're a lot cheaper to tackle than having anyone poke around in the dash.
Old Apr 21, 2010 | 09:28 AM
Ram1371's Avatar
Ram1371
Mine does the same thing if I top off the tank.
There is no wiring problem. Runner the scanner displays a fuel vapor canister code. Running the tank down and 3 warm sarts will eventually clear the code.
