DIY Front Brake Pads
lol sorry matt
Caliper slider pins must be checked to make sure they move easily. If they're stuck, excessive pad wear will result.
No brake job is complete unless this is done.
Torque specs.
Front caliper adapter mounting bolts tighten to 176 N·m (130 ft.lbs.)
Rear caliper adapter mounting bolts 135 N·m (100 ft.lbs)
Front caliper slide pin bolts. tighten to 32 N·m (24 ft. lbs.)
Rear caliper mounting slide pin bolts tighten to 15 N·m (11 ft. lbs.).
Re grease caliper slider sleeves with high temp silicone grease.
Hope this helps?
Al.
Torque specs.
Hope this helps?
Al.
yea pretty sure the rears will be similar
I agree with Al on the torque specs.
Good Job though and you don't really need to write a Novel as I am sure this DIY will help someone on their first time who dosn't got a Haynes or Free Download Service Manual. If ever in doubt always do one side at a time so if you get confused you have an opposite example to look at on the assembled side, especially if you need to replace those hidden little parking brake shoes in the back (if rear seals leaking they'll be toast).
From personnal lessons learned it is good to clean and or replace the Bleeder screw on the caliper(s) and dab some anti-seize on re-install as they point upward in a chamfered hole that collects dirt, mud and if you don't bleed em for a couple years your chances of them breaking off next time you loosen them is reduced.
Also although the Caliper mounting bolts are torqued at 130 I put em in with some blue threadlocker (so next time you gotta clean out the threads).
