3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
Only difference with the rears are a smaller rotor and single piston for each side. Other than that they are identical. Well, that and you don't have the luxury to turn the hub for a better angle at removing the caliper mount bolts.
Plus the caliper slider bolts front/rear have different size bolt heads.
Al.
