Old Aug 13, 2015, 08:46 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Dodge Ram 1500 Exterior Guides
Print Wikipost
How do i Remove Grille and Paint front Ram Head
Old Apr 26, 2010 | 04:16 PM
Brado34's Avatar
Brado34
Default How do i Remove Grille and Paint front Ram Head
How do i remove the grille?
from the looks the only way is to break the plastic pieces that hold it on.. if i do that how will i get it back on?
also.. to paint the ram head do i paint it on the truck and just mask it all off... or should i pop it off
Old Apr 26, 2010 | 04:19 PM
jroy's Avatar
jroy
To remove the inserts you need to remove the grill shell because one of the plastic rivets holding the inserts in is behind the grill shell. To remove the grill shell there's 4 or 6 bolts along the bottom and 4 or 6 bolts along the top. To remove the inserts from the shell you need to push the center pieces out of the rivets before you will be able to pull the rivets out.
Old Apr 26, 2010 | 04:22 PM
98cherryram's Avatar
98cherryram
Yeah, you dont have to break anything to get them off!! Just play around with it a little and you will figure it out! And you can get the ram head out, its just in the grill with 3 little punch slots. Mine is painted black.
Old Apr 26, 2010 | 05:01 PM
Brado34's Avatar
Brado34
dude i got a bug deflector and i just tryed to get er off with a putty knife and a flat head no luck... if anything it was bending the ram head
Old Apr 26, 2010 | 05:05 PM
cheapbeater's Avatar
cheapbeater
try the fishing line trick on the ram head... take some braided fishing line and "saw" that thing off... assuming it is glued to the bug guard...
the grille unbolts from the hood...
Old Apr 26, 2010 | 05:12 PM
Brado34's Avatar
Brado34
hmm i guess i could try that..
for the grille and ram head should i use color matching paint that i already have... or some flat black that i already have..
im going to clear coat them both no matter what..
anyone have or know of a dyi to remove the ram head and chrome grille inserts..
if i take off thouse bolts will the whole black grille fall off along with the chrome inserts?
Old Apr 26, 2010 | 05:46 PM
Brado34's Avatar
Brado34
yeah guys the rams head isnt coming off.. i got most of it to come off.. ( the outtering ring) but then it started to crack.. i think i may just have to paint it on the truck and maby slip a piece of paper under it or something..
the grille... if i take off thouse bolts the whole grille is going to come off.. i just want the silver inserts out.
Old Apr 26, 2010 | 05:50 PM
JoeHemi's Avatar
JoeHemi
the easiest way to take the inserts out is to remove the whole grille, place the grille face down on a sturdy surface, then push out the rivets. Also, you may have better luck removing the ram head once the grille is off since you'll have a better angle. You can try to sit on the front bumper and pull the hood down over you and try to pop out those rivets. I would guess that's possible but I've never done it that way.
Old Apr 26, 2010 | 05:54 PM
Brado34's Avatar
Brado34
man im really considering just drilling holes through the rivets so that i dont have to pop em out.. there a real pain in the ***..
as for the head.. i just dont know.. im not even sure what its held on by.
Old Apr 26, 2010 | 05:59 PM
rocket23's Avatar
rocket23
isn't that ram head a stick on?? if so you use fiching line and a torch too loosen up the glue and saw your way through. takes a while. If it;s riveted then yeah drill from behind. you should be able to just get the revit itself without hitting the grill.
