Any autobody men here?
Old 05-02-2010, 07:23 PM
AF_HEMI's Avatar
AF_HEMI
AF_HEMI is offline
i cant wait to see this done...
Old 05-02-2010, 07:27 PM
Brado34's Avatar
Brado34
Brado34 is offline
ohh dude its gona take for ever! ive got the hood already. 25$ off kijiji.. its like craigslist..
has a dent in er but what ever.. i gotta find a place to get it sand blasted so im not sitting around for 3 days sanding my brains away.
im going to take pictures maby make a diy
Old 05-02-2010, 08:21 PM
Unperfected's Avatar
Unperfected
Unperfected is offline
ok heres what u do and the right way...... as long as the scoop has a flat edge (lip) to it ur good. The right way to do it is to go to napa and buy some good panel bond. put the scoop on and trace it out. Grind the hood and the scoop where they will meet each other. You will want the 45 min setting panel bond because what you will do is when u have ground the hood and scoop where they meet with the most agressive stuff possible smeer the panel bond on both mateing surfaces. Once u have done that so that way its sealed from rust put a good beed of panel bond on the hood. Then drill and RIVET the scoop down every 4 inches or so and in the corners. Let it drie and then grind the rivet heads off if there in the way if not go ahead and lay down a coat of short stran fibre glass. Once thats dried sand it down and repeat. when its close then go to bondo when there very little body work needed
im in oshawa ont where u at?
Old 05-02-2010, 08:30 PM
AF_HEMI's Avatar
AF_HEMI
AF_HEMI is offline
SENTENCES!! lol
Old 05-02-2010, 09:37 PM
Brado34's Avatar
Brado34
Brado34 is offline
im all the way down in burlington.. between hamilton and oakville.
probally an hour and a half away
so grinding down the good vs just sand blasting will allow it to stick better correct? how deep down would i grind the lips? i was just planning on bondo'ing out about 6 inches to blend it in for the whole 3 mm it will probally consume
Old 05-02-2010, 09:41 PM
Brado34's Avatar
Brado34
Brado34 is offline
metal or plastic rivets?
Old 05-02-2010, 11:14 PM
4matty3's Avatar
4matty3
4matty3 is offline
good idea. that scoop is sweet. good luck
Old 05-02-2010, 11:33 PM
Brado34's Avatar
Brado34
Brado34 is offline
any tips as to how i would keep the water out of the side vents? im just going to make the scoop non functional il try to sneak a grille in it so you cant tell.
Old 05-03-2010, 12:58 AM
rocket23's Avatar
rocket23
rocket23 is offline
Seems like you got it figured out you guy's montreal fan's yet?? Your inserts for the hood can be picked up on jc whitney I believe . You can also fab up a pair . They are only drip trays . from what i've seen.btw.
Old 05-03-2010, 11:47 AM
Brado34's Avatar
Brado34
Brado34 is offline
what inserts are you talking about? lol youve lost me.. also drip trays?
Quick Reply: Any autobody men here?
