DIY - Cold Air intake?
Old May 5, 2010 | 05:27 PM
  #21
hoss67's Avatar
hoss67
Originally Posted by SoCalDodge
After reading these threads, sounds like DIY is the way to go. One question, was making the shield difficult? or fitting it?
Not really just got a thin sheet about 3x3 drew where i need to cut and bend, i made holes where the old air filter sat so i can place the new one in the same place and that was pretty much it.. oh and i bolted it on at the top to the back, u can see in the pick
Old May 5, 2010 | 07:29 PM
  #22
HammerZ71's Avatar
HammerZ71
Yeah, I kinda figure out the best way as I go. I made one for a Wrangler and used no box, the one I made for Pyro, he had a fleabay intake that broke that came with the shield, so that was easy, with a buddies Z71 and Cowboy Johnny's, I used the existing air box sans top, the one I just shipped out also replaces a broken one that used no box, so I basically routed it close to the sidewall to use a bracket I fab'd up and then used a 45 to angle it back out and down towards the wheel well.
I think if I'm gonna keep getting asked to make these, I'm gonna start charging a little for my labor and use the money to invest in a small brake, so I can bend boxes for them.
Old May 5, 2010 | 07:31 PM
  #23
rocket23's Avatar
rocket23
When there is a will there is away
Old May 5, 2010 | 11:17 PM
  #24
SoCalDodge's Avatar
SoCalDodge
Oh ok awesome, looks like I've got my next project planned then. Thanks!
Old May 6, 2010 | 10:04 AM
  #25
bball14's Avatar
bball14
Does anyone know if I could expect a decent gain with a DIY cold air intake without using a tuner?
Old May 6, 2010 | 12:10 PM
  #26
HammerZ71's Avatar
HammerZ71
Ballpark you can expect in the neighborhood of 8-14 HP at the crank depending on filter used...
Old May 6, 2010 | 01:32 PM
  #27
hoss67's Avatar
hoss67
im at work right now till late, i will try to take some pics of mine and i will pm them to you so u can get better view of wat im talkin about
Old May 6, 2010 | 02:06 PM
  #28
HammerZ71's Avatar
HammerZ71
I was going to do a full DIY when Johnny came over to do his, but really what was I gonna take pics of, me with a measuring tape in my hand and cutting PVC on a miter saw???
