Overhead Console Install
Is that the EVIC unit (that I referenced in the last post)?
My friends '08 is a 2500 (actually the Power Wagon) and it doesn't look like that.
New electrical system for 2006. 02-05 are PCI bus, 06 and up CAN bus. You CAN bus guys get to use the MyGig stereo.
Hey,I've got a 2006 Ram crew cab sxt and just bought a console # 56045574AD.My truck has no wires running to the area.You seem knowledgeable,any suggestionz on how to make it work and whaf else I will need?
The correct module numbers for your year are 56049824AC (without homelink) and 56044864AC (with homelink). The module you have listed comes up for a 2003. This likely won't work because Rams went from a PCI Bus data/electrical system to a CAN bus in 2006. Once you get the right module and console, you will need a harness, either a junkyard one with enough length to splice in, or if you make one. You would need either this, this, or this.
