SLT exterior door trim
Old May 5, 2010 | 02:40 PM
Ramghost3's Avatar
Ramghost3
Default SLT exterior door trim
How difficult is it to add the black slt exterior door trim? Are they clipped in (which probably would require cutting notches in the door?) or just applied with an adhesive?
Thanks for the help in advance
Old May 5, 2010 | 02:42 PM
OlDirtyJohn's Avatar
OlDirtyJohn
what door trim are you talking about exactly? if you are referring to the door spears down near the bottom of the door, they just stick on with adhesive.
cwboyjohnny24's Avatar
cwboyjohnny24
They're put on with adhesive. You can use 3m adhesive tape. You're putting a badge on? Most people are takin' 'em off.
Old May 5, 2010 | 02:44 PM
new2this's Avatar
new2this
i wanna say its an adhesive, i couldnt imagine any modern car manufacturer cutting notches in the metal to add some body side cladding. if its the spears on the driver and passenger side doors you are talking about, i know lots of guys on here have stripped those off in the debadging process so im pretty sure those are adhesive as well.
Old May 5, 2010 | 02:51 PM
Ramghost3's Avatar
Ramghost3
Thanks for the replies! Yep, the spears that run along the bottom half of the door. That's great if they just glue on, was thinking on the older ram I had they were clipped in, but maybe it was glued on. I wanted to add the door spear trim but didn't want it bad enough to cut in the door just for the clips....
Old May 5, 2010 | 03:03 PM
cwboyjohnny24
Yes, they're put on with adhesive. Just in my opinion those spears look silly. I'm just saying that because that's my opinion. Unless they're color matched they just don't look right.
Old May 5, 2010 | 03:29 PM
Ramghost3's Avatar
Ramghost3
Probably just used to the way my old dodge looked with the spear trim and tailgate trim. Guess most newer models don't have the trim, but it really saves the doors from getting chipped and dinged in the parking lot
Old May 5, 2010 | 04:47 PM
RedTruck-VA's Avatar
RedTruck-VA
No door spears on mine. I park in the far corner of the lot and set safety cones all around it. lol....
