Air filter maintenance?
Has any one maintained their air filters with oil yet? Aren't you supposed too clean the filter with a special product from k&n or spectre. then re oil the filter? I heard some where at least once a year. This should be done.
Also application om the filtr is only on the ridges not the valleys, any thoughts on this. thanks guys in advance.
on
Trending Topics
And, you are correct in that you oil the peaks and not the valleys....the idea being that the filter 'wicks' the oil down into the valleys. You oil the filter, then wait a period of time (it says how long in the instructions), then re-check to see that the valleys have turned dark pink, as well. If not, you reapply a bit more oil. But don't overdo it!
