Throttle Body Cleaning
Old 05-19-2010, 04:42 PM
cwboyjohnny24's Avatar
cwboyjohnny24
cwboyjohnny24 is offline
I would say pull it and clean it well. I don't know about this not smooth 4.7 thing......mine idles real well. No jumps in rpm.
Old 05-19-2010, 07:28 PM
Markmm0000's Avatar
Markmm0000
Markmm0000 is offline
use carb/throttlebody cleaner too some people swear by break cleaner but its too rough on the gaskets.
Old 05-19-2010, 07:30 PM
aldenjj's Avatar
aldenjj
aldenjj is offline
Default RPM issue
Mine seems to idle a little rough, not enough to affect the RPMs, but not real smooth either. I was just wondering if that is normal. I don't want to be trying to fix something that isn't broken.
Old 05-19-2010, 07:32 PM
aldenjj's Avatar
aldenjj
aldenjj is offline
When I cleaned it originally I used carb/throttle cleaner, but I didn't remove the throttle body. I held the blade open, and scrubbed the back side with a toothbrush, then wiped clean.
Old 05-19-2010, 09:10 PM
mc35's Avatar
mc35
mc35 is offline
Taking it off is reallllllyyy easy....So I don't see why you wouldn't go ahead and take it off. I did mine the other day and it literally took me 15 minutes to get it off, clean it, and put it back on.
Old 05-19-2010, 11:35 PM
bananafarmer's Avatar
bananafarmer
bananafarmer is offline
my idles very jumpy. i have cleaned the throttle body and i was looking for the egr, but i have no idea where it is i looked around for about an hour today to try and find it with no luck. can anyone point me to where it would be in a 4.7L
Old 05-19-2010, 11:45 PM
mc35's Avatar
mc35
mc35 is offline
I think this is what your looking for....correct me if that's not it...
Old 05-20-2010, 12:13 AM
bananafarmer
can you clean the egr somehow or do you just replace it
Old 05-20-2010, 08:55 AM
weedahoe's Avatar
weedahoe
weedahoe is offline
Hall of Fame Member
You can clean the EGR but because it is an emssions device you should replace it as a whole and also since it is cheap.
Not break cleaner but brake cleaner and there are no gaskets on the TB. The gasket is on the intake which you do not remove. Either way with carb or brake cleaner, you want it to be non-chlorinated.
Old 05-20-2010, 09:22 AM
aldenjj's Avatar
aldenjj
aldenjj is offline
Default Egr
Is there anyway to know if the EGR is getting weak, or not performing at 100%.....other than throwing a code?
Quick Reply: Throttle Body Cleaning
