swapping to srt 60
Old May 23, 2010 | 11:29 PM
  #21
HemiLonestar's Avatar
HemiLonestar
Originally Posted by Shiloh 24
I personally like the idea of it, but I don't like the price for the conversion just for a coolness factor. Even though I have had some VERY VERY close calls with my stock calipers and rotors, I'll prolly go drilled and slotted before I ever think of going SRT.
I don't blame you, I had the truck for about 5 years before I did it, and then only because I get hella good deals on everything.
Old May 23, 2010 | 11:50 PM
  #22
blownhemiram05's Avatar
blownhemiram05
why would you want an srt rear end anyway... arent they the cause for may flipped srt10's
http://www.youtube.com/watch?v=NjAy9Tp2Op0
Old May 24, 2010 | 12:39 AM
  #23
HemiLonestar
Yeah, when there's a retard up front...
Old May 24, 2010 | 01:03 AM
  #24
RedTruck-VA's Avatar
RedTruck-VA
Yeah, that had nothing to do with the rear axle, the guy just couldn't drive. The SRT is plenty strong and from the OP install costing about the same as a standard Ram gear/diff upgrade. if I had the choice to make again, I'd go for the SRT axle.
Old Jul 14, 2010 | 01:08 AM
  #25
dickyshemi's Avatar
dickyshemi
ok guys so heres the skinny..i ordered a srt rear end when i posted this last the rear end showed up was a huge mess..not only was it a 9.25 out of a st it had no brakes..the place i orderd let me return it. so after searching and comming up with nothing i had the 9.25 rebuilt again by a well known shop and it went out again thinking houseing is tweaked? so searched and found a place call x2 builders they had several srt rear ends
so i ordered a quad cab one...there customer service is awsome and the guy who took the rear out of the srt took there time cause nothing was cut it was all there..rear end brakes e cables leaf springs shocks u bolts ect....it was a compleat plug and play set up. I should have done this the second time...so all the parts where 1000.00 +250 for shipping so 1250.00
then i will let you guy know how much will have to cut or add to the drive line + a yoke and U joint and ill post lots of pics...thank you for all of your guys help i would not have know about the swap if it was not for this site..again thanks...oh yeah the swap took me an hour and 10min by myself....=) p.s my spedo is 5mph off so if you have an awnser for that let me know? thanks
Old Jul 15, 2010 | 01:16 AM
  #26
HemiLonestar
Programmer.
Old Jul 16, 2010 | 10:32 PM
  #27
dickyshemi's Avatar
dickyshemi
up date so it was 1000.00 for the rear end 250 for shipping..had to get the driveshaft cut down 1/2 inch and a new yoke installed wich was 200.17 bringin the total bill to 1450.17 well worth it..
Old Jul 16, 2010 | 10:35 PM
  #28
dickyshemi's Avatar
dickyshemi
also you have to have 17" wheels for the swap..thers a 1/4" of space between the wheel and caliper
Old Jul 16, 2010 | 10:44 PM
  #29
HemiLonestar
For the rears, I'm guessing you didn't convert the fronts (those you're stuck with 20" wheels minimum).
Old Jul 17, 2010 | 12:04 PM
  #30
dickyshemi's Avatar
dickyshemi
nope just the rear. rotors are about the same size but the rear calipers are bigger stops nice..
