T-pipe vs. CAI
Old May 31, 2010 | 07:50 PM
9511234's Avatar
9511234
Default T-pipe vs. CAI
What would you do, is it possible to do a homebrew T-pipe?
Advantages vs. Disadvantages of each?
Old May 31, 2010 | 08:13 PM
JOHNSN10's Avatar
JOHNSN10
whats a t pipe? is that the cai with 2 filters?
Old May 31, 2010 | 08:17 PM
9511234's Avatar
9511234
That's what I was thinking it was called ... just saw both ways and wasn't sure of an advantage or disadvantage.
Old May 31, 2010 | 08:28 PM
AF_HEMI's Avatar
AF_HEMI
it really doesnt matter either way. A regular CAI shoves about as much CFM into the engine as it'll take, so having more air going in isnt gonna make a bit of difference. You can chug from a garden hose or a fire hose, either way you can only take in so much water. In this case its air into the engine.
There are 2 reasons people do the T-intake. 1) its different and looks cool. 2) it opens up the fender wall for something else (like a second battery).
Old May 31, 2010 | 08:36 PM
nozmadd0x's Avatar
nozmadd0x
I was also looking at the t-pipes, you can get them on ebay for around $60 and it would allow me to do both things AF Hemi mentioned; it looks cool, its different, it increases air intake, and it would allow me to put a battery for my sound system where the original box was.
Old May 31, 2010 | 08:39 PM
AF_HEMI's Avatar
AF_HEMI
I never said it increase air intake. Actually it doesnt. It throws more air at the engine, but i doesnt go anywhere cause the engine can only inhale so much air. There is ZERO advantage performance-wise to the T-pipe vs. regular.
Old May 31, 2010 | 08:49 PM
nozmadd0x's Avatar
nozmadd0x
I understand that the engine can only bring in so much air but I thought there were enough studies done that it was pretty much accepted that the stock box with the crappy filter does not give the engine all the air it really wants, especially when paired with a new high flow exhaust. Like drinking out of a hose with a very fine mesh grate over it, take off the grate and the water flows much more freely.
Old May 31, 2010 | 09:28 PM
Denniss66's Avatar
Denniss66
i would of figured the dual filters would be at a disadvantage seeings how they sit right above the motor. is there not alot more heat sitting right above the motor where as a normal cai or even the home brew ones you can tuck down behind the bumper or headlight where there is no heat around it.
Old May 31, 2010 | 09:31 PM
AF_HEMI's Avatar
AF_HEMI
Ah i see, we're comparing apples and oranges. I was saying there is no performance difference over the T-pipe vs the regular aftermarket CAI (like K/N). You're absolutely right about the stock box. Anything will flow better than the stock "hemi hat" system.
There is more heat from the motor up there, but there is also a lot of wind coming in through the grille.
Old May 31, 2010 | 09:35 PM
Denniss66's Avatar
Denniss66
ic well im still gonna play with my homebrew cai got the pvc just need to do the cutting and painting once i figure out where i want it.
