Engine Light Came on
Old Jun 5, 2010 | 01:17 AM
Steve Ruddy's Avatar
Steve Ruddy
Default Engine Light Came on
I just checked my spark plugs and they looked like the original plugs and if so they had 72,000 miles on them. The gap was .065 and should be .045. Anyway I decided to replace them and do an oil change. The parts store only got me 4 so I went ahead and replaced 4 and did the oil change. Right after doing this the engine light came on. Any ideas way? Can I reset it and what is the least expensive code reader for my truck? It's a 2004 5.7L.
Thanks,
Old Jun 7, 2010 | 09:09 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
What was the code for the CEL? Could be something related to the plugs and might not be. Need the codes to know for sure.
Old Jun 7, 2010 | 10:59 AM
Denniss66's Avatar
Denniss66
as weedahoe said codes would be good to know if you don't know how the check it you just turn the key on and off 3 times in a row leaving the key in the on position after the 3rd time without starting it and the codes should show up where the odometer is.
Old Jun 7, 2010 | 11:08 AM
stenerson's Avatar
stenerson
If you have an autozone nearby they will read your codes for free.
Old Jun 7, 2010 | 02:23 PM
nh5's Avatar
nh5
why would you change only 4 plugs? gotta get the other 12 and get em done. I wouldn't mix new and old plugs.
Old Jun 8, 2010 | 06:01 PM
Steve Ruddy
That didn't work for my truck so I purchased this http://www.actron.com/product_detail.php?pid=16318
I replaced the rest of the plugs but the light is still on. I'm assuming I will need to reset the computer after I retrieve the codes. I will let you all know which codes show up.
Thanks,
Steve
Old Jun 8, 2010 | 06:19 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Yeah the key switch trick doesnt work on 04s
Old Jun 20, 2010 | 11:01 AM
Steve Ruddy
I purchased an Actron CP9180. Wow what a nice tool. The code came up as P0441 Evap Control system purse flow fault. I found this description on OBD-Codes.com but it doesn't appear to be related to spark plugs.
Anyway I finally replaced the rest of the plugs. I didn't realize there were 16 until nh5 metioned it. I also cleared the code and it hasn't come back and it's been a week now so I hope all is well.
Thanks,
Old Jun 20, 2010 | 01:31 PM
lxman1's Avatar
lxman1
Site Moderator
Gas cap loose?
Old Jun 20, 2010 | 01:38 PM
mudkicker78's Avatar
mudkicker78
Probably something origanally left loose when you were doing the sparkplugs
