Help me choose a spindle lift kit
Old Jun 7, 2010 | 09:29 PM
cordaco's Avatar
cordaco
Default Help me choose a spindle lift kit
What spindles are you using for your 2WD 04 ram and what can you tell me about them? I'm looking at purchasing a set with a 4"lift.
Old Jun 8, 2010 | 08:49 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
You can use several types. I had 3" Rough Country spindles on mine at one point. You can go to www.airbagit.com and find some there also as well as Ebay.
Old Jun 8, 2010 | 09:19 AM
cwboyjohnny24's Avatar
cwboyjohnny24
Also for a decent price for a full kit, look at the 6" lift on Roughcountry.com.
Old Jun 8, 2010 | 11:44 PM
cordaco's Avatar
cordaco
Did you fellas have problems with the wheel offset?
Old Jun 9, 2010 | 07:51 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
What problem? Your rims and tires you have now will work.
Old Jun 9, 2010 | 01:20 PM
OlDirtyJohn's Avatar
OlDirtyJohn
unless you have factory 17's. then, in that case, you must have 4.5" of backspacing for the rims to clear the new spindles.
Old Jun 9, 2010 | 01:39 PM
cwboyjohnny24
Exactly, and if I'm not mistaken not even the factory 20's have that much backspacing. If you're gonna run the factory rim you just need to get a set of spacers.
Old Jun 26, 2010 | 05:25 PM
red ram ridin's Avatar
red ram ridin
So you cannot clear 4 inch spindles with factory 17 inch rims? Running 285's
Old Jun 26, 2010 | 05:30 PM
red ram ridin
army_hemi2wd is running stock rims on a 3in spindle lift
Old Jun 26, 2010 | 07:51 PM
OlDirtyJohn
the 20" wheels will clear them. the lift spindle is longer than stock, and rides inside the rim. so the diameter of a 17" is not enough. but the diameter of the 20" rim is big enough to allow the spindle to fit inside. with aftermarket wheels with the correct back spacing, it pushes the rim out so that the spindle does not sit inside the rim.
tire size plays no part in any of this.
