3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
As long as you have cats on there you will have a shot at passing inspection.
That is what I am hoping. I am also going to have the exhaust shop weld in an extra O2 bung so I can add a wideband later. Where do you have your wideband bung?
I have a converter with dual bungs. So there is the front O2 in the header collector, then the wideband sensor in the front converter bung and the rear O2 in the second converter bung.
You cheated with yours teach... I was so close to going that rout too though so I gues I cant talk to much there. We had to drill a hole and eld the bung into the Pacesetter Y with mine since I kept the stock cats
No before the driveside cat. We spliced the Pacesetter Y and welded in the cats so we could slide the fittings onto the collectors and not weld them on.
