cover rear vent ok?
Old Jun 15, 2010 | 09:10 PM
fewmopar's Avatar
fewmopar
Default cover rear vent ok?
I have a 06 Hemi quad cab with noisey dual exhaust and I gutted the rear seat area and I'm putting dynamat all through it. Is there any reason at all why I can't or should'nt cover those vents back behind the back seat. I'm sure noise comes in through them. I'm not sure how much though.
Old Jun 15, 2010 | 09:14 PM
COTFAN's Avatar
COTFAN
That is part of the ventilation system. They open/close depending on recirculated a/c etc.
Old Jun 15, 2010 | 10:39 PM
AF_HEMI's Avatar
AF_HEMI
DO NOT cover these. These are absolutely necessary to allow pressure to escape when you close the doors as well as turning on the A/C. Anyone who says anything different doesnt know what they're talking about. Leave them alone. Your eardrums will thank you
Old Jun 15, 2010 | 11:36 PM
Matt99's Avatar
Matt99
close em off, it wont hurt anything
Old Jun 16, 2010 | 12:32 AM
AF_HEMI's Avatar
AF_HEMI
screw you matt haha
Old Jun 16, 2010 | 12:34 AM
AF_HEMI's Avatar
AF_HEMI
you're seriously using dynamat? ugh... you probably run flowmaster for better flow too dont you.
do some research buddy. dynamat is the most overpriced stuff on the market. its realllllllly not worth the price. There is much better stuff out there for less money.
Old Jun 16, 2010 | 08:07 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Do not cover them. Without them open, when you turn on the air conditioning or anything else you will over pressurize the cab. That means the incoming air has to go somewhere and the next easiest exit point are your door seals. And with that comes water leakage eventually.
Old Jun 16, 2010 | 09:22 AM
RubberFrog's Avatar
RubberFrog
How are you going to get rid of your farts?
Seriously though, your biggest problem will be on hot days when your door seals start blowing out in the parking lot.
