Trouble with eFan Mod??
Old Jun 17, 2010 | 03:03 PM
RubberFrog's Avatar
RubberFrog
If you've got plenty of spares, you're golden. I would do the same thing in that case.
Old Jun 17, 2010 | 06:01 PM
lxman1's Avatar
lxman1
Site Moderator
The low speed draws 16amps when running, I have had the Hayden all in 1 relay/ adj thermostat kit on my Mustang for over a year and have had no issues. High speed running draws 42amps (I have an amp clamp for testing) My has a 180 thermostat and never got over 192 in 96 degree very humid weather the other day with the a/c blowing cold. You shouldn't need high speed anyway because the fan is not needed over about 25mph anyway, only for low speed cruising and idling unless perhaps towing, say 7500lbs, up along steep upgrade.
Old Jun 22, 2010 | 11:28 AM
ekgaudio's Avatar
ekgaudio
Sorry guys for the delayed response but i'm just working on my fan today.
-Frog,
What relay are you running in that setup?
And your suppose to have the fan pull air from the radiator right? Not push.
Old Jun 22, 2010 | 11:42 AM
RedTruck-VA's Avatar
RedTruck-VA
-Frog,
Fan mounted behind the radiator pulling air through the radiator blowing toward the engine.
Old Jun 22, 2010 | 11:57 AM
ekgaudio's Avatar
ekgaudio
Thanks Redtruck. Im digging into it now to re-wire, hopefully i get a better outcome.
